hello, I'm requesting data from a website to use in a project. However, I need to put the city and the type of tariff before getting the data, so that the http request and the html cannot pull the value
From the http request node help text
When configured within the node, the URL property can contain mustache-style tags. These allow the url to be constructed using values of the incoming message. For example, if the url is set to
example.com/{{{topic}}}, it will have the value ofmsg.topicautomatically inserted. Using {{{...}}} prevents mustache from escaping characters like / & etc
So if you had the msg properties
msg.one set to string "text"
msg.two set to number 10
You could enter the url in the http request node as
http://example.com?string={{one}}&number={{two}}
The mustache template would convert it to
http://example.com?string=text&number=10
Alternatively you could leave the url input blank and constuct thr url prior to the http request node, setting it to msg.url and the http request node would use that url.
As the help text says
url (string)
If not configured in the node, this optional property sets the url of the request.
https://agenciavirtual.sabesp.com.br/web/guest/tarifas
esse é o site que preciso retirar os dados mas preciso colocar os dados primeiro o que me impede usar o request
[translation: provided by moderator]
this is the site where I need to get the data but I need to put the data first which prevents me from using the request
You need to post better questions with more explanation.
The issue you are having then is the site posts a form to fetch the data, you will have to replicate the form request, or use Nbrowser or Puppeteer Nodes to load the page with Javascript and submit the form. Neither is a simple task.
