Hello
I have a dashboard with template node
But the date in my database is on format YYYY-MM-DD, after select on Mysql the value is in format
What is the solution for any value il in my template in format YYYY-MM-DD not GTM
Since you are French-speaking, don't you want this kind of format?
"20/12/2012 04:00:00"
Take a look here, I don't know if you can use it directly in the template or if you have to modify the message before
<td><center>{{msg.payload[$index].date.toLocaleString('fr-FR', { timeZone: 'UTC' })}}</center></td>
I changed it like that but it doesn't work
I would think you can adjust your sql statement to get the correct format.
this is my request mysql
SELECT * FROM authorized ORDER BY name ASC, lastname ASC
Would need to know column types, to make a reply that would work. But try naming the columns instead of *, and also you can use sql functions on the columns then. Dont for get to use AS name function to make the returned object properties more readable.
e.g
SELECT DATE_FORMAT(date_column, "%Y") AS date....
https://dev.mysql.com/doc/refman/8.0/en/date-and-time-functions.html#function_date-format
Try with
{{new Date(msg.payload[$index].date).toLocaleString('fr-FR', { timeZone: 'UTC' })}}
no i have no entry in my table with this format
Modify the format in msg.payload before you pass it to the template node.
Try
SELECT
ID,
name,
lastname,
plate,
DATE_FORMAT(date, "%Y-%m-%d") AS date
FROM
authorized
ORDER BY
name ASC,
lastname ASC;
Or similar
this is good but the code is
msg.topic = "SELECT ID ,name, lastname,plate, DATE_FORMAT(date, '%Y-%m-%d') AS date FROM authorized ORDER BY name ASC, lastname ASC"; return msg;
If you want the dates to show in your local time,
you'll have to use an additional CONVERT_TZ mysql date function
in order to first convert it to your timezone and then format it ..
otherwise the dates would sometimes show incorrectly.
so adding to @E1cid 's solution
SELECT ID, name, lastname, plate, DATE_FORMAT(CONVERT_TZ(date,'+00:00','+10:00'), '%Y-%m-%d') AS date FROM authorized ORDER BY name ASC, lastname ASC
+10:00 as an example. adjust to your local tz
