Date Format wrong?
Hello everyone
I have a problem with my script. I'm getting errors sleepStart and SleepEnd. I guess in date format ? "const diffMs = sleepEnd - sleepStart;" Can someone help me ?
// Überprüfen, ob die Konvertierung erfolgreich war
if (isNaN(sleepStart.getTime()) || isNaN(sleepEnd.getTime())) {
    node.error("Ungültige Datumsangaben für 'sleepStart' oder 'sleepEnd'.");
    return null;
// Berechne die Differenz in Millisekunden und konvertiere in Stunden und Minuten
const diffHours = Math.floor(diffMs / (1000 * 60 * 60)); // Ganze Stunden
const diffMinutes = Math.floor((diffMs % (1000 * 60 * 60)) / (1000 * 60)); // Verbleibende Minuten
// Ausgabe der Differenz als z. B. "8:45"
msg.payload = `${diffHours}:${diffMinutes.toString().padStart(2, '0')}`;
// Rückgabe der Nachricht mit der berechneten Schlafdauer
where do the variables sleepStart and sleepEnd come from?
they are not declared in your code.
It is a good idea to post a simple flow with an inject node and your function node to show the problem.
here's the flow:
Your flow file is not posted correctly and is corrupt
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
   code goes here
You can edit and correct your post by clicking the pencil :pencil2: icon.
You JSON file is not a JSON and all but useless.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value for any data item.
BX00Cy7yHi
To the issue
sleepEnd and sleepStart are still time objects, you have not create variables that contain the getime() integers. Try creating two new vars using sleepEnd.getTime(), and use these vars for your calculation.
very nice, thank you
