Hi, can somebody help me, i’m using node-red-contrib modbus and I have a button on dashboard that when actuated will synchronize the datetime between node red and my controller, need help to create Function to pack the Date & Time into byte array to send via modbus protocol from RPI to my controller, it would be 2 bytes per Modbus register.
I just want to put last 2 digit of a year in byte0 and the month value in byte1, day value in byte2, hour value in byte3,mins. value in byte4, secs value in byte5; byte 0 and 1 will be one 16 Bit unsigned integer, byte1 & 2, next 16 bit integer.. i will then input it to a modbus node.
Which bit don't you know how to do? Getting the year, month etc or packing them into the integers?
If you don't know how to the get the date/time values then have a look at [1]. Have a play with those methods in a function node and see how you get on. While experimenting you can use node.warn to show values in the debug panel. So you might start with
let now = new Date();
let year = now.getUTCFullYear();
node.warn("year is " + year);
Thank you Colin for giving me direction.. now i can write the year to my controller , now i need to pack it to integer with the one byte containing the month, can you please show me. here's what I did.
let month = now.setUTCMonth();
msg.payload = year - 2000;
node.warn( msg);
That shifts the month value left 8 bits before adding it to the year which should be what you want I think. You will be in trouble after the year 2127 but I don't suppose you will lose much sleep over that. Of course that is exactly what the first programmers thought about the year 2000
Thank you ill try that, its just a hobby project so just getting started, so after its running ill keep improving it, Ill remember ur advise about 2127.
