I suspect the node you are using uses that library. It is to much of a coincidence.
This is true, its not a secret. Its basicly the same. But I dont know how could it help me, to prevent getting log files that big.
do you have the Debugging option in the node checked off?
If so, uncheck it and see what happens. With it checked it causes the underlining node (GitHub - Apollon77/smartmeter-obis: This library supports the reading and parsing of smartmeter protocols that follow the OBIS number logic to make their data available.) to do 'Detailed' logging
Also (in answer to your GitHub question) the Request Interval is seconds
I'm not sure I was using it. I know that is now unchecked.
I will run some tests later with checked debugging box and then with unchecked.
allright, looks like debugging was checked, when I was running it. Because I tested it now. When debugging is checked, then this messages gets stored and the log file is rising quickly. With unchecked the measurment dont get stored inside deamon.log
Thanks everyone for help!
