Debug window doesn't show any info?
Why doesnt my debug window show the debug message outputs in my flow?
[{"id":"e6693df7.a3cfa","type":"tab","label":"Flow 4","disabled":false,"info":""},{"id":"eb571ded.e53f3","type":"modbus-read","z":"e6693df7.a3cfa","name":"","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"1","dataType":"HoldingRegister","adr":"0","quantity":"21","rate":"1","rateUnit":"m","delayOnStart":false,"startDelayTime":"","server":"4264d3c1.ded4fc","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":90,"y":200,"wires":[["797d3ae5.38d634","9a6a4156.4097f"],["7cef1789.59d0b8","2259213f.81dade"]]},{"id":"797d3ae5.38d634","type":"function","z":"e6693df7.a3cfa","name":"","func":"// var msg2 = {payload : msg.payload[1]/10};\n// msg.payload = String.fromCharCode(msg.payload);\n\n//var msg1 = {payload : String.fromCharCode(msg.payload[0])};\n//var msg2 = {payload : String.fromCharCode(msg.payload[1])};\n//var msg3 = {payload : String.fromCharCode(msg.payload[2])};\n//var msg4 = {payload : String.fromCharCode(msg.payload[3])};\n//var msg5 = {payload : String.fromCharCode(msg.payload[4])};\n//var msg6 = {payload : String.fromCharCode(msg.payload[5])};\n//var msg7 = {payload : String.fromCharCode(msg.payload[6])};\n//var msg8 = {payload : String.fromCharCode(msg.payload[7])};\n//var msg9 = {payload : String.fromCharCode(msg.payload[8])};\n//var msg10 = {payload : String.fromCharCode(msg.payload[9])};\n//var msg11 = {payload : String.fromCharCode(msg.payload[10])};\n//var msg12 = {payload : String.fromCharCode(msg.payload[11])};\n//var msg13 = {payload : String.fromCharCode(msg.payload[12])};\n//var msg14 = {payload : String.fromCharCode(msg.payload[13])};\n//var msg15 = {payload : String.fromCharCode(msg.payload[14])};\n//var msg16 = {payload : String.fromCharCode(msg.payload[15])};\n//var msg17 = {payload : String.fromCharCode(msg.payload[16])};\n//var msg18 = {payload : String.fromCharCode(msg.payload[17])};\n//var msg19 = {payload : String.fromCharCode(msg.payload[18])};\n//var msg20 = {payload : String.fromCharCode(msg.payload[19])};\n\n\nvar msg1 = {payload : msg.payload[0]};\nvar msg2 = {payload : msg.payload[1]};\nvar msg3 = {payload : msg.payload[2]};\nvar msg4 = {payload : msg.payload[3]};\nvar msg5 = {payload : msg.payload[4]};\nvar msg6 = {payload : msg.payload[5]};\nvar msg7 = {payload : msg.payload[6]};\nvar msg8 = {payload : msg.payload[7]};\nvar msg9 = {payload : msg.payload[8]};\nvar msg10 = {payload : msg.payload[9]};\nvar msg11 = {payload : msg.payload[10]};\nvar msg12 = {payload : msg.payload[11]};\nvar msg13 = {payload : msg.payload[12]};\nvar msg14 = {payload : msg.payload[13]};\nvar msg15 = {payload : msg.payload[14]};\nvar msg16 = {payload : msg.payload[15]};\nvar msg17 = {payload : msg.payload[16]};\nvar msg18 = {payload : msg.payload[17]};\nvar msg19 = {payload : msg.payload[18]};\nvar msg20 = {payload : msg.payload[19]};\nvar msg21 = {payload : msg.payload[20]};\n\n\n\n//return [msg1, msg2, msg3, msg4, msg5, msg6, msg7, msg8, msg9, msg10, msg11, msg12, msg13, msg14, msg15, msg16, msg17, msg18, msg19, msg20];\n\n\n\n msg.payload = {\n//  value: msg.payload[0], msg.payload[1], msg.payload[2], msg.payload[3], msg.payload[4], msg.payload[5], msg.payload[6], msg.payload[7], msg.payload[8], msg.payload[9], msg.payload[10], msg.payload[11], msg.payload[12], msg.payload[13], msg.payload[14], msg.payload[15], msg.payload[16], msg.payload[17], msg.payload[18], msg.payload[19],\n  value: msg.payload,\n  'fc': 16, \n  'unitid': 1, \n  'address': 100 , // Have to subtract one from PLC modbus\n  'quantity': 21 } \n // return msg;\n return [msg,msg.payload[20]];","outputs":2,"noerr":0,"initialize":"","finalize":"","x":280,"y":200,"wires":[[],["d74a4291.c4218"]]},{"id":"d74a4291.c4218","type":"switch","z":"e6693df7.a3cfa","name":"","property":"payload[20]","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"neq","v":"1","vt":"num"}],"checkall":"false","repair":false,"outputs":2,"x":370,"y":40,"wires":[["68d47360.93fddc","de556cb9.d8bda"],["18e4e521.874d8b"]]},{"id":"68d47360.93fddc","type":"function","z":"e6693df7.a3cfa","name":"","func":"\nmsg.site = 'AC'\n//msg.serial = msg.payload\nmsg.serial = 'BVGL01272'\n\n\nvar parse1 = '<?xml version=\"1.0\" encoding=\"utf-8\"?>';\nparse1 = parse1 + '\\n' + '<soap:Envelope xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" xmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\">';\nparse1 = parse1 + '\\n' + '  <soap:Header>';\nparse1 = parse1 + '\\n' + '    <SoapSettings xmlns=\"http://tempuri.org/\">';\nparse1 = parse1 + '\\n' + '      <IsTest>false</IsTest>';\nparse1 = parse1 + '\\n' + '      <ApplicationID>105B9760-A4A0-4659-BE09-2B6F64980DBD</ApplicationID>';\nparse1 = parse1 + '\\n' + '      <ApplicationKey>C565C1F9-A326-4754-B654-CFA059865820</ApplicationKey>';\nparse1 = parse1 + '\\n' + '    </SoapSettings>';\nparse1 = parse1 + '\\n' + '  </soap:Header>';\nparse1 = parse1 + '\\n' + '  <soap:Body>'\nparse1 = parse1 + '\\n' + '    <GetNamePlateInfoBySite xmlns=\"http://tempuri.org/\">';\nparse1 = parse1 + '\\n' + '      <unitSerialNumber>' + msg.serial + '</unitSerialNumber>';\nparse1 = parse1 + '\\n' + '      <site>' + msg.site + '</site>';\nparse1 = parse1 + '\\n' + '      <billNum>' + msg.billNum + '</billNum>';\nparse1 = parse1 + '\\n' + '    </GetNamePlateInfoBySite>';\nparse1 = parse1 + '\\n' + '  </soap:Body>';\nparse1 = parse1 + '\\n' + '</soap:Envelope>';\nmsg.payload = parse1;\nreturn msg;\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":520,"y":40,"wires":[["3337f067.a4ca1"]]},{"id":"3337f067.a4ca1","type":"simple-soap","z":"e6693df7.a3cfa","host":"http://172.16.16.38:8095/MainframeWs/MainframeService.asmx","hostType":"str","path":"","pathType":"str","action":"http://tempuri.org/GetNamePlateInfoBySite","actionType":"str","body":"payload","bodyType":"msg","mustache":false,"attrkey":"$","charkey":"_","stripPrefix":false,"simplify":false,"normalizeTags":false,"normalize":false,"topic":"","name":"","useAuth":false,"x":650,"y":40,"wires":[["aea8c9ea.e82588"]]},{"id":"aea8c9ea.e82588","type":"function","z":"e6693df7.a3cfa","name":"","func":"\nglobal.set(\"CHARGEPERSYSTEM1\",msg.payload[\"soap:Envelope\"][\"soap:Body\"].GetNamePlateInfoBySiteResponse.GetNamePlateInfoBySiteResult[\"diffgr:diffgram\"].DocumentElement.Data.CHARGEPERSYSTEM1)\nglobal.set(\"CHARGEPERSYSTEM2\",msg.payload[\"soap:Envelope\"][\"soap:Body\"].GetNamePlateInfoBySiteResponse.GetNamePlateInfoBySiteResult[\"diffgr:diffgram\"].DocumentElement.Data.CHARGEPERSYSTEM2)\nglobal.set(\"CHARGEPERSYSTEM3\",msg.payload[\"soap:Envelope\"][\"soap:Body\"].GetNamePlateInfoBySiteResponse.GetNamePlateInfoBySiteResult[\"diffgr:diffgram\"].DocumentElement.Data.CHARGEPERSYSTEM3)\nglobal.set(\"CHARGEPERSYSTEM4\",msg.payload[\"soap:Envelope\"][\"soap:Body\"].GetNamePlateInfoBySiteResponse.GetNamePlateInfoBySiteResult[\"diffgr:diffgram\"].DocumentElement.Data.CHARGEPERSYSTEM4)\nglobal.set(\"CHARGEPERSYSTEM5\",msg.payload[\"soap:Envelope\"][\"soap:Body\"].GetNamePlateInfoBySiteResponse.GetNamePlateInfoBySiteResult[\"diffgr:diffgram\"].DocumentElement.Data.CHARGEPERSYSTEM5)\nglobal.set(\"CHARGEPERSYSTEM6\",msg.payload[\"soap:Envelope\"][\"soap:Body\"].GetNamePlateInfoBySiteResponse.GetNamePlateInfoBySiteResult[\"diffgr:diffgram\"].DocumentElement.Data.CHARGEPERSYSTEM6)\nglobal.set(\"CHARGEPERSYSTEM7\",msg.payload[\"soap:Envelope\"][\"soap:Body\"].GetNamePlateInfoBySiteResponse.GetNamePlateInfoBySiteResult[\"diffgr:diffgram\"].DocumentElement.Data.CHARGEPERSYSTEM7)\nglobal.set(\"CHARGEPERSYSTEM8\",msg.payload[\"soap:Envelope\"][\"soap:Body\"].GetNamePlateInfoBySiteResponse.GetNamePlateInfoBySiteResult[\"diffgr:diffgram\"].DocumentElement.Data.CHARGEPERSYSTEM8)\n\n\nmsg.CHARGEPERSYSTEM1 = global.get(\"CHARGEPERSYSTEM1\");\nmsg.CHARGEPERSYSTEM2 = global.get(\"CHARGEPERSYSTEM2\");\nmsg.CHARGEPERSYSTEM3 = global.get(\"CHARGEPERSYSTEM3\");\nmsg.CHARGEPERSYSTEM4 = global.get(\"CHARGEPERSYSTEM4\");\nmsg.CHARGEPERSYSTEM5 = global.get(\"CHARGEPERSYSTEM5\");\nmsg.CHARGEPERSYSTEM6 = global.get(\"CHARGEPERSYSTEM6\");\nmsg.CHARGEPERSYSTEM7 = global.get(\"CHARGEPERSYSTEM7\");\nmsg.CHARGEPERSYSTEM8 = global.get(\"CHARGEPERSYSTEM8\");\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":790,"y":40,"wires":[[]]},{"id":"aae2126f.4fe7f","type":"debug","z":"e6693df7.a3cfa","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":490,"y":240,"wires":[]},{"id":"2259213f.81dade","type":"debug","z":"e6693df7.a3cfa","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":80,"y":300,"wires":[]},{"id":"9a6a4156.4097f","type":"debug","z":"e6693df7.a3cfa","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":70,"y":100,"wires":[]},{"id":"18e4e521.874d8b","type":"debug","z":"e6693df7.a3cfa","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":490,"y":160,"wires":[]},{"id":"de556cb9.d8bda","type":"debug","z":"e6693df7.a3cfa","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":530,"y":120,"wires":[]},{"id":"7cef1789.59d0b8","type":"function","z":"e6693df7.a3cfa","name":"","func":"msg = msg.payload[20]\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":310,"y":300,"wires":[["aae2126f.4fe7f"]]},{"id":"4264d3c1.ded4fc","type":"modbus-client","z":"","name":"PLC","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"10.3.40.30","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":1,"commandDelay":1,"clientTimeout":1000,"reconnectOnTimeout":true,"reconnectTimeout":2000,"parallelUnitIdsAllowed":true}]
Do you get any debug output at all in the debug window or is it just some debug that doesn't show?
Are you sure that there are messages going into the debug nodes?
If you configure an inject node directly into a debug node does that work?
In addition to Colin's questions, can you share any information on how/where you are running Node-RED? Is it on a local device? Or are you running it behind some sort of proxy?
Thats a good question. If I try this simple flow I get debug outputs so it works but just not on the flow i posted. It must not be working correclty which I dont understand yet. It writes the modbus points to my plc so it seems like it is working but just no debug info
Which node in the flow you posted is writing to the PLC?
If you add an inject node feeding one of the debug nodes does that work?
Also set the debug pane to All Nodes if it isn't already.
Getting something now. I set the modbus read to show activity and saw the error that i had it pointed to the wrong system. Upon straitening that out im getting stuff now. Do we mark this thread as complete or erase it if not really solved in a useful way to others?
You can mark it as solved by clicking the three dots at the bottom of the post that solved it and then clicking Solved.
