Hi.
A new deepstack problem.
Running this on a Nvidia Jetson.
If I send a picture using a http request node and a function node it's working perfect.
But when I use node-red-contrib-deepstack
I get Input buffer contains unsupported image format.
have spent sever hours now to get this to work.
Anyone knows if sharp has any log file? or how I can locate the problem?
build options
native win32: no
native OS X: no
open files in binary mode: no
enable debug: no
enable deprecated library components: yes
enable docs with gtkdoc: no
gobject introspection: no
enable radiance support: yes
enable analyze support: yes
enable PPM support: yes -
optional dependencies
use fftw3 for FFT: no
Magick package: none
Magick API version: none
load with libMagick: no
save with libMagick: no
accelerate loops with orc: yes
(requires orc-0.4.11 or later)
ICC profile support with lcms: no
file import with niftiio: no
file import with libheif: no
file import with OpenEXR: no
file import with OpenSlide: no
(requires openslide-3.3.0 or later)
file import with matio: no
PDF import with PDFium: no
PDF import with poppler-glib: no
(requires poppler-glib 0.16.0 or later)
SVG import with librsvg-2.0: no
(requires librsvg-2.0 2.34.0 or later)
zlib: yes
file import with cfitsio: no
file import/export with libwebp: no
(requires libwebp, libwebpmux, libwebpdemux 0.6.0 or later)
text rendering with pangoft2: yes
file import/export with libspng: no
(requires libspng-0.6 or later)
file import/export with libpng: yes (pkg-config libpng >= 1.2.9)
(requires libpng-1.2.9 or later)
support 8bpp PNG quantisation: no
(requires libimagequant)
file import/export with libtiff: no
file import/export with giflib: no
file import/export with libjpeg: yes (pkg-config)
image pyramid export: no
(requires libgsf-1 1.14.26 or later)
use libexif to load/save JPEG metadata: no
Now type 'make' to compile vips
