Deepstack missing node types
Hi.
Installed deepstack in node-red but i get an error when i using Objekt and face detection.
Any idea how to find out what causing this?
/Niclas
25 Jun 08:47:28 - [debug] saved flow revision: 1f3ae501292e2c3f964fc45f4e510ba4
25 Jun 08:47:28 - [info] Stopping flows
25 Jun 08:47:28 - [info] Stopped flows
25 Jun 08:47:28 - [info] Waiting for missing types to be registered:
25 Jun 08:47:28 - [info] - server
25 Jun 08:47:28 - [info] - deepstack-object-detection
25 Jun 08:47:28 - [info] - deepstack-face-recognition
25 Jun 08:47:28 - [trace] runtime event: {"id":"runtime-state","payload":{"error":"missing-types","type":"warning","text":"notification.warnings.missing-types","types":["server","deepstack-object-detection","deepstack-face-recognition"]},"retain":true}
25 Jun 08:47:28 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"1f3ae501292e2c3f964fc45f4e510ba4"},"retain":true}
Seems like some of the nodes in node-red-contrib-deepstack have failed to load.
There will likely be an error in the node-red start up log output.
What versions of node-js and node-red are you using? It might be this set of nodes dont play nicely with a really old node-red or node-js version.
I am running latest version of node-red 1.3.5 and node JS v14.17.
startup log looks like this
5 Jun 09:55:30 - [warn] ------------------------------------------------------
25 Jun 09:55:30 - [info] Settings file : /home/niclas/.node-red/settings.js
25 Jun 09:55:30 - [info] Context store : 'default' [module=memory]
25 Jun 09:55:30 - [info] User directory : /home/niclas/.node-red
25 Jun 09:55:30 - [warn] Projects disabled : editorTheme.projects.enabled=false
25 Jun 09:55:30 - [info] Flows file : /home/niclas/.node-red/stop
25 Jun 09:55:30 - [info] Creating new flow file
25 Jun 09:55:30 - [debug] loaded flow revision: d751713988987e9331980363e24189ce
25 Jun 09:55:30 - [debug] red/runtime/nodes/credentials.load : no user key present
25 Jun 09:55:30 - [debug] red/runtime/nodes/credentials.load : using default key
25 Jun 09:55:30 - [debug] red/runtime/nodes/credentials.load : keyType=system
your credentials.
25 Jun 09:55:30 - [trace] runtime event: {"id":"runtime-state","retain":true}
25 Jun 09:55:30 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"d751713988987e9331980363e24189ce"},"retain":true}
25 Jun 09:55:30 - [info] Starting flows
25 Jun 09:55:30 - [debug] red/nodes/flows.start : starting flow : global
25 Jun 09:55:30 - [trace] [flow:global] start flow [global]
25 Jun 09:55:30 - [info] Started flows
25 Jun 09:55:30 - [info] Server now running at http://127.0.0.1:1880/
That looks fairly normal.
Try refreshing browser?
Actually, you have entered node-red stop instead of node-red-stop
this has created a brand new empty flow file - thats why it looks normal and without error.
ok we try again :slight_smile:
and now I see that something is wrong with sharp.
i will try to reinstall.
Thanks for helping!!!
โ”‚ **id** โ”‚ **name** โ”‚ **namespace** โ”‚ **version** โ”‚ **mode** โ”‚ **pid** โ”‚ **uptime** โ”‚ **โ†บ** โ”‚ **status** โ”‚ **cpu** โ”‚ **mem** โ”‚ **user** โ”‚ **watching** โ”‚
โ”œโ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ค
โ”‚ **0** โ”‚ node-red โ”‚ default โ”‚ N/A โ”‚ **fork** โ”‚ 0 โ”‚ 0 โ”‚ 0 โ”‚ **stopped** โ”‚ 0% โ”‚ 0b โ”‚ **niclas** โ”‚ disabled โ”‚
โ””โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”˜
**niclas@niclas-desktop** : **~** $ node-red
25 Jun 10:30:06 - [info]
Welcome to Node-RED
25 Jun 10:30:06 - [info] Node-RED version: v1.3.5
25 Jun 10:30:06 - [info] Node.js version: v14.17.1
25 Jun 10:30:06 - [info] Linux 4.9.201-tegra arm64 LE
25 Jun 10:30:07 - [info] Loading palette nodes
25 Jun 10:30:07 - [debug] Module: node-red-contrib-deepstack 0.1.2 /home/niclas/.node-red/node_modules/node-red-contrib-deepstack
25 Jun 10:30:07 - [debug] Module: node-red-dashboard 2.29.3 /home/niclas/.node-red/node_modules/node-red-dashboard
25 Jun 10:30:07 - [debug] Module: node-red-node-rbe 0.5.0 /usr/local/lib/node_modules/node-red/node_modules/node-red-node-rbe
25 Jun 10:30:07 - [debug] Module: node-red-node-tail 0.3.1 /usr/local/lib/node_modules/node-red/node_modules/node-red-node-tail
25 Jun 10:30:08 - [info] Dashboard version 2.29.3 started at /ui
25 Jun 10:30:08 - [warn] ------------------------------------------------------
25 Jun 10:30:08 - [warn] [node-red-contrib-deepstack/deepstack-object-detection] Error:
Something went wrong installing the "sharp" module
libvips-cpp.so.42: cannot open shared object file: No such file or directory
- Remove the "node_modules/sharp" directory then run
"npm install --ignore-scripts=false --verbose sharp" and look for errors
- Consult the installation documentation at https://sharp.pixelplumbing.com/install
- Search for this error at https://github.com/lovell/sharp/issues
25 Jun 10:30:08 - [warn] [node-red-contrib-deepstack/deepstack-face-recognition] Error:
25 Jun 10:30:08 - [info] Settings file : /home/niclas/.node-red/settings.js
25 Jun 10:30:08 - [info] Context store : 'default' [module=memory]
25 Jun 10:30:08 - [info] User directory : /home/niclas/.node-red
25 Jun 10:30:08 - [warn] Projects disabled : editorTheme.projects.enabled=false
25 Jun 10:30:08 - [info] Flows file : /home/niclas/.node-red/flows_niclas-desktop.json
25 Jun 10:30:08 - [info] Server now running at http://127.0.0.1:1880/
25 Jun 10:30:08 - [debug] loaded flow revision: 36bd8b18a6bd616995421873f5f84039
25 Jun 10:30:08 - [debug] red/runtime/nodes/credentials.load : no user key present
25 Jun 10:30:08 - [debug] red/runtime/nodes/credentials.load : using default key
25 Jun 10:30:08 - [debug] red/runtime/nodes/credentials.load : keyType=system
your credentials.
25 Jun 10:30:08 - [trace] runtime event: {"id":"runtime-state","retain":true}
25 Jun 10:30:08 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"36bd8b18a6bd616995421873f5f84039"},"retain":true}
25 Jun 10:30:08 - [info] Waiting for missing types to be registered:
25 Jun 10:30:08 - [info] - server
25 Jun 10:30:08 - [info] - deepstack-object-detection
25 Jun 10:30:08 - [trace] runtime event: {"id":"runtime-state","payload":{"error":"missing-types","type":"warning","text":"notification.warnings.missing-types","types":["server","deepstack-object-detection"]},"retain":true}
25 Jun 10:30:38 - [trace] comms.open kxLBOHKvf3wUdBPUMYSPzJ67rYNWcglTrdiMzIZ5ewE=
Have reinstalled all packages, Libvips and sharp with no errors and it still not working. Any idea how to find out what's the problem?
Regards Niclas
Do you mean you are still getting the same "Something went wrong installing the "sharp" module" message when starting Node-RED?
If not, are there any new errors in the startup log?
What board/processor is this running on ? Is the app known to run in this board without Node-RED ?
I am running a Nvidia Jetson. But I solved it at last. the problem was libvips. I downgraded to version 8.10.5 instead of 8.11.0 and then it worked.
Thanks for your support
/Niclas
How do you rate the performance of Deepstack when running on the Jetson? Is it utilizing the GPU?
I run YOLO v4 on my Jetson's and used the guides in here:
Also interesting with Deepstack is of course that you can register faces with it
It might be a good idea to submit an issue about that on the node's github page so that the author can take appropriate action.
Hi. Yes it utilizing the GPU. Have just tried objekt detection so far and it takes about 500ms to process an hi-res jpg.
