I have tried to make some progress bar using chart bar and mytimeout node. So I have 5 horizontal chart bar which means 5 steps of my program. When the first mytimeout is over, another one begins and so on. So I can have many steps running one after each other. But it looks I have a delay when one mytimeout is over and when the new one begins... Someone has an idea ?
Thank you
[{"id":"24095369.3ba49c","type":"tab","label":"Flow 11","disabled":false,"info":""},{"id":"7c6c7448.8bde5c","type":"ui_chart","z":"24095369.3ba49c","name":"","group":"448586ea.7f42a8","order":2,"width":6,"height":2,"label":"Fmax Droite N1","chartType":"horizontalBar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"3","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#ff3333","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1320,"y":380,"wires":[[]]},{"id":"ea35b564.b74718","type":"mytimeout","z":"24095369.3ba49c","name":"Fmax Droite N1","outtopic":"","outsafe":"","outwarning":"","outunsafe":"off","warning":"0","timer":"3","debug":false,"ndebug":false,"ignoreCase":false,"repeat":false,"again":false,"x":1020,"y":380,"wires":[["1bcf5fe1.b61d9"],["7c6c7448.8bde5c"]]},{"id":"1926930.9633b6d","type":"mytimeout","z":"24095369.3ba49c","name":"Recup Fmax N1","outtopic":"","outsafe":"","outwarning":"","outunsafe":"off","warning":"0","timer":"3","debug":false,"ndebug":false,"ignoreCase":false,"repeat":false,"again":false,"x":1020,"y":580,"wires":[["7155d527.f2ae6c"],["44553cbc.cbb974"]]},{"id":"1bcf5fe1.b61d9","type":"function","z":"24095369.3ba49c","name":"","func":"if (msg.payload == 'off') {\n msg.payload = 'on'\n}\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":500,"wires":[["1926930.9633b6d"]]},{"id":"44553cbc.cbb974","type":"ui_chart","z":"24095369.3ba49c","name":"","group":"448586ea.7f42a8","order":3,"width":6,"height":2,"label":"Recup Post Fmax N1","chartType":"horizontalBar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"3","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1340,"y":580,"wires":[[]]},{"id":"5bc83a09.4924d4","type":"function","z":"24095369.3ba49c","name":"","func":"msg.payload = 3\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":620,"wires":[["7c6c7448.8bde5c","44553cbc.cbb974","788a24ce.b5d11c","f5cb9d51.25cbb","ffdd6657.7974e8"]]},{"id":"788a24ce.b5d11c","type":"ui_chart","z":"24095369.3ba49c","name":"","group":"448586ea.7f42a8","order":4,"width":6,"height":2,"label":"Fmax Droite N2","chartType":"horizontalBar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"3","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#ff3333","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1320,"y":760,"wires":[[]]},{"id":"73da4ea1.bca96","type":"mytimeout","z":"24095369.3ba49c","name":"Fmax Droite N2","outtopic":"","outsafe":"","outwarning":"","outunsafe":"off","warning":"0","timer":"3","debug":false,"ndebug":false,"ignoreCase":false,"repeat":false,"again":false,"x":1020,"y":760,"wires":[["172c3b1b.69ca85"],["788a24ce.b5d11c"]]},{"id":"4a6a4347.2d280c","type":"mytimeout","z":"24095369.3ba49c","name":"Recup Fmax N2","outtopic":"","outsafe":"","outwarning":"","outunsafe":"off","warning":"0","timer":"3","debug":false,"ndebug":false,"ignoreCase":false,"repeat":false,"again":false,"x":1020,"y":940,"wires":[[],["f5cb9d51.25cbb","abe89208.ceeb1"]]},{"id":"172c3b1b.69ca85","type":"function","z":"24095369.3ba49c","name":"","func":"if (msg.payload == 'off') {\n msg.payload = 'on'\n}\nreturn msg;","outputs":1,"noerr":0,"x":850,"y":860,"wires":[["4a6a4347.2d280c"]]},{"id":"f5cb9d51.25cbb","type":"ui_chart","z":"24095369.3ba49c","name":"","group":"448586ea.7f42a8","order":5,"width":6,"height":2,"label":"Recup Post Fmax N2","chartType":"horizontalBar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"3","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1340,"y":940,"wires":[[]]},{"id":"7155d527.f2ae6c","type":"function","z":"24095369.3ba49c","name":"","func":"if (msg.payload == 'off') {\n msg.payload = 'on'\n}\nreturn msg;","outputs":1,"noerr":0,"x":850,"y":680,"wires":[["73da4ea1.bca96"]]},{"id":"a5347043.afc05","type":"mytimeout","z":"24095369.3ba49c","name":"Préparation","outtopic":"","outsafe":"","outwarning":"","outunsafe":"off","warning":"0","timer":"3","debug":false,"ndebug":false,"ignoreCase":false,"repeat":false,"again":false,"x":1010,"y":180,"wires":[["de9b1309.05b59"],["ffdd6657.7974e8"]]},{"id":"ffdd6657.7974e8","type":"ui_chart","z":"24095369.3ba49c","name":"","group":"448586ea.7f42a8","order":1,"width":6,"height":2,"label":"Préparation","chartType":"horizontalBar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"3","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#f2f155","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1310,"y":180,"wires":[[]]},{"id":"de9b1309.05b59","type":"function","z":"24095369.3ba49c","name":"","func":"if (msg.payload == 'off') {\n msg.payload = 'on'\n}\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":280,"wires":[["ea35b564.b74718"]]},{"id":"2bc8f415.f15abc","type":"ui_button","z":"24095369.3ba49c","name":"","group":"77e8a1e0.4442a","order":5,"width":0,"height":0,"passthru":false,"label":"Quand vous êtes prêts, cliquez ici ","tooltip":"","color":"","bgcolor":"","icon":"","payload":"on","payloadType":"str","topic":"","x":480,"y":120,"wires":[["a5347043.afc05","77091505.3e085c"]]},{"id":"77091505.3e085c","type":"function","z":"24095369.3ba49c","name":"","func":"var now = new Date();\nmsg.payload = now.getTime();\nflow.set('t1', msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":600,"y":260,"wires":[["99462f8b.767b9"]]},{"id":"99462f8b.767b9","type":"debug","z":"24095369.3ba49c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":580,"y":400,"wires":[]},{"id":"369383b2.8308ec","type":"debug","z":"24095369.3ba49c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1530,"y":240,"wires":[]},{"id":"d58e121.3a232f","type":"inject","z":"24095369.3ba49c","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":350,"y":620,"wires":[["5bc83a09.4924d4"]]},{"id":"abe89208.ceeb1","type":"function","z":"24095369.3ba49c","name":"","func":"if (msg.payload === 0) {\n msg.payload = new Date().getTime();\n flow.set('t2', msg.payload);\n}\nreturn msg;","outputs":1,"noerr":0,"x":1280,"y":240,"wires":[["369383b2.8308ec"]]},{"id":"9420fc40.3e53f","type":"debug","z":"24095369.3ba49c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":950,"y":1060,"wires":[]},{"id":"e4f3f1ac.e9f0b","type":"function","z":"24095369.3ba49c","name":"","func":"msg.payload = flow.get('t2') - flow.get('t1');\nreturn msg;","outputs":1,"noerr":0,"x":770,"y":1060,"wires":[["9420fc40.3e53f"]]},{"id":"e9677333.7f267","type":"inject","z":"24095369.3ba49c","name":"Tstop - Tstart","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":570,"y":1060,"wires":[["e4f3f1ac.e9f0b"]]},{"id":"ba90e488.d01f78","type":"inject","z":"24095369.3ba49c","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":320,"y":180,"wires":[["a5347043.afc05","77091505.3e085c"]]},{"id":"448586ea.7f42a8","type":"ui_group","z":"","name":"Compte à rebours","tab":"f75bbc9f.a03b1","order":3,"disp":true,"width":"6","collapse":false},{"id":"77e8a1e0.4442a","type":"ui_group","z":"","name":"Préparation au test","tab":"f75bbc9f.a03b1","order":2,"disp":true,"width":"6","collapse":false},{"id":"f75bbc9f.a03b1","type":"ui_tab","z":"","name":"Préhension SELFIT","icon":"dashboard","order":4,"disabled":false,"hidden":false}]
