Delete characters
i want delete of the first twelve characters received from a UDP network message?
in the beginning of the network message, the date and time are indicated, I do not want forward this information.
I just want to recover the information that is after the date and time.
example UDP network message received:
20_06_20 12:30:02 alarm triggering input 1
I wish to simply forward or use:
alarm trigger input 1
thanks for your return
You can add a function node that calls substr
msg.payload = msg.payload.substr(18);
Proof....
Probably also possible in a change node with JSONata
thanks for your help, it works perfectly
