Strip character from text string
I get some data from a sensor that looks like
2023
I assume the little arrow in the front of the text must be some kind of carriage return? I haven't figured out how to strip that from the payload. That character is always the first but the length of the payload varies
thanks
You can do in a function node
msg.payload = msg.payload.substring(1)
This will return the string minus the first character.
sorry but the funky character still shows up when I use that in a function
To remove any whitespace before and after, in a function node use.
msg.payload = msg.payload.trim()
Or in a chnage node and JSONata
use
$trim($$.payload)
And there is also the contrib string node.
EDIT by @Paul-Reed - correct typo
that's the ticket !!
thanks
If what you actually want is the number, then you can use
msg.payload = Number(msg.payload)
