Delete , edite , send row of table
hi . i have a project which select some data's from nodes , and show them in table at dashboard, now I want add select bar to each row at table to delete or edit or send it to DB, how i can do them ?
        "id": "36348c32365b6b66",
        "type": "tab",
        "label": "bridge lighting",
        "disabled": false,
        "info": "",
        "env": []
        "id": "152bce1c24dfcab7",
        "type": "ui_dropdown",
        "z": "36348c32365b6b66",
        "label": "انتخاب سال ",
        "tooltip": "",
        "place": "Select option",
        "group": "6305d8128da6cbab",
        "order": 1,
        "width": "9",
        "height": "1",
        "passthru": true,
        "multiple": false,
        "options": [
                "label": "1402",
                "value": "1402",
                "type": "str"
                "label": "1403",
                "value": "1403",
                "type": "str"
                "label": "1404",
                "value": "1404",
                "type": "str"
                "label": "1405",
                "value": "1405",
                "type": "str"
                "label": "1406",
                "value": "1406",
                "type": "str"
                "label": "1407",
                "value": "1407",
                "type": "str"
                "label": "1408",
                "value": "1408",
                "type": "str"
                "label": "1409",
                "value": "1409",
                "type": "str"
                "label": "1410",
                "value": "1410",
                "type": "str"
        "payload": "",
        "topic": "year",
        "topicType": "str",
        "className": "",
        "x": 660,
        "y": 160,
                "81363a2d27fbc7c3"
        "id": "f82d933954275f0d",
        "label": "انتخاب ماه ",
        "tooltip": "",
        "order": 2,
        "width": "9",
        "height": 1,
        "passthru": true,
        "multiple": false,
        "options": [
                "label": "فروردین ",
                "value": "1",
                "type": "str"
                "label": "اردیبهشت ",
                "value": "2",
                "type": "str"
                "label": "خرداد",
                "value": "3",
                "type": "str"
                "label": "تیر ",
                "value": "4",
                "type": "str"
                "label": "مرداد",
                "value": "5",
                "type": "str"
                "label": "شهریور",
                "value": "6",
                "type": "str"
                "label": "مهر",
                "value": "7",
                "type": "str"
                "label": "آبان ",
                "value": "8",
                "type": "str"
                "label": "آذر",
                "value": "9",
                "type": "str"
                "label": " دی ",
                "value": "10",
                "type": "str"
                "label": "بهمن ",
                "value": "11",
                "type": "str"
                "label": "اسفند ",
                "value": "12",
                "type": "str"
        "payload": "",
        "topic": "month",
        "topicType": "str",
        "className": "",
        "x": 660,
        "y": 220,
                "81363a2d27fbc7c3"
        "id": "9d3aed3a25d93d3f",
        "label": "انتخاب روز از ماه",
        "tooltip": "",
        "order": 3,
        "width": "9",
        "height": 1,
        "passthru": true,
        "multiple": false,
        "options": [
                "label": "",
                "value": "1",
                "type": "str"
                "label": "",
                "value": "2",
                "type": "str"
                "label": "",
                "value": "3",
                "type": "str"
                "label": "",
                "value": "4",
                "type": "str"
                "label": "",
                "value": "5",
                "type": "str"
                "label": "",
                "value": "6",
                "type": "str"
                "label": "",
                "value": "7",
                "type": "str"
                "label": "",
                "value": "8",
                "type": "str"
                "label": "",
                "value": "9",
                "type": "str"
                "label": "",
                "value": "10",
                "type": "str"
                "label": "",
                "value": "11",
                "type": "str"
                "label": "",
                "value": "12",
                "type": "str"
                "label": "",
                "value": "13",
                "type": "str"
                "label": "",
                "value": "14",
                "type": "str"
                "label": "",
                "value": "15",
                "type": "str"
                "label": "",
                "value": "16",
                "type": "str"
                "label": "",
                "value": "17",
                "type": "str"
                "label": "",
                "value": "18",
                "type": "str"
                "label": "",
                "value": "19",
                "type": "str"
                "label": "",
                "value": "20",
                "type": "str"
                "label": "",
                "value": "21",
                "type": "str"
                "label": "",
                "value": "22",
                "type": "str"
                "label": "",
                "value": "23",
                "type": "str"
                "label": "",
                "value": "24",
                "type": "str"
                "label": "",
                "value": "25",
                "type": "str"
                "label": "",
                "value": "26",
                "type": "str"
                "label": "",
                "value": "27",
                "type": "str"
                "label": "",
                "value": "28",
                "type": "str"
                "label": "",
                "value": "29",
                "type": "str"
                "label": "",
                "value": "30",
                "type": "str"
                "label": "",
                "value": "31",
                "type": "str"
        "payload": "",
        "topic": "day",
        "topicType": "str",
        "className": "",
        "x": 680,
        "y": 260,
                "81363a2d27fbc7c3"
        "id": "b952f36f30a14385",
        "type": "ui_form",
        "name": "Schedule Form",
        "label": "",
        "order": 4,
        "width": "9",
        "height": "2",
        "options": [
                "label": "Start Time (HH:MM)",
                "value": "startTime",
                "type": "text",
                "required": true,
                "rows": null
                "label": "Finish Time (HH:MM)",
                "value": "finishTime",
                "type": "text",
                "required": true,
                "rows": null
        "formValue": {
            "startTime": "",
            "finishTime": ""
        "payload": "{}",
        "submit": "submit",
        "cancel": "",
        "topic": "time",
        "topicType": "str",
        "splitLayout": false,
        "className": "",
        "x": 680,
        "y": 300,
                "81363a2d27fbc7c3"
        "id": "0122d72eabb1d981",
        "type": "ui_table",
        "name": "زمانبندی ",
        "order": 6,
        "width": "7",
        "height": "5",
        "columns": [
                "field": "yearData",
                "title": "yearData",
                "width": "",
                "align": "center",
                "formatter": "plaintext",
                "formatterParams": {
                    "target": "_blank"
                "field": "monthData",
                "title": "monthData",
                "width": "",
                "align": "center",
                    "target": "_blank"
                "field": "dayData",
                "title": "روز",
                "width": "",
                "align": "center",
                    "target": "_blank"
                "field": "timeStartData",
                "title": "ساعت شروع",
                "width": "",
                "align": "center",
                    "target": "_blank"
                "field": "timeFinishData",
                "title": "ساعت پایان ",
                "width": "",
                "align": "left",
                    "target": "_blank"
                "field": "effectData",
                "title": "افکت",
                "width": "",
                "align": "left",
                    "target": "_blank"
        "outputs": 1,
        "cts": true,
        "x": 1270,
        "y": 240,
                "99aa178ef64a181f"
        "id": "81363a2d27fbc7c3",
        "type": "function",
        "name": "Format for Table",
        "func": "var yearData = flow.get(\"yearData\") || [];\nvar monthData = flow.get(\"monthData\") || [];\nvar dayData = flow.get(\"dayData\") || [];\nvar timeStartData = flow.get(\"timeStartData\") || [];\nvar timeFinishData = flow.get(\"timeFinishData\") || [];\nvar effectData = flow.get(\"effectData\") || [];\n\nswitch (msg.topic) {\n    case \"year\":\n        yearData.push(msg.payload);\n        flow.set(\"yearData\", yearData);\n        break;\n    case \"month\":\n        monthData.push(msg.payload);\n        flow.set(\"monthData\", monthData);\n        break;\n    case \"day\":\n        dayData.push(msg.payload);\n        flow.set(\"dayData\", dayData);\n        break;\n    case \"time\":\n        if (msg.payload.hasOwnProperty(\"startTime\") && msg.payload.hasOwnProperty(\"finishTime\")) {\n            timeStartData.push(msg.payload.startTime);\n            timeFinishData.push(msg.payload.finishTime);\n            flow.set(\"timeStartData\", timeStartData);\n            flow.set(\"timeFinishData\", timeFinishData);\n        }\n        break;\n    case \"effect\":\n        effectData.push(msg.payload);\n        flow.set(\"effectData\", effectData);\n        break;\n}\n\nvar tableData = [];\n\nfor (var i = 0; i < Math.max(yearData.length, monthData.length, dayData.length, timeStartData.length, timeFinishData.length, effectData.length); i++) {\n    var row = {\n        'yearData': yearData[i] || \"\",\n        'monthData': monthData[i] || \"\",\n        'dayData': dayData[i] || \"\",\n        'timeStartData': timeStartData[i] || \"\",\n        'timeFinishData': timeFinishData[i] || \"\",\n        'effectData': effectData[i] || \"\"\n    };\n    tableData.push(row);\n}\n\nreturn { payload: tableData };\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1100,
        "y": 240,
                "0122d72eabb1d981"
        "id": "99aa178ef64a181f",
        "type": "debug",
        "name": "debug 8",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1420,
        "y": 240,
        "id": "e94ecbf3784daf18",
        "type": "ui_button",
        "name": "edit",
        "order": 9,
        "width": "2",
        "height": "1",
        "passthru": false,
        "label": "edit",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "edit",
        "payload": "edit",
        "payloadType": "str",
        "topic": "topic",
        "topicType": "msg",
        "x": 670,
        "y": 460,
        "id": "3bbb7dec5e635afb",
        "name": "send",
        "order": 8,
        "width": "2",
        "height": "1",
        "passthru": false,
        "label": "send",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "send",
        "payload": "send",
        "topic": "topic",
        "topicType": "msg",
        "x": 670,
        "y": 420,
        "id": "3e440484554451cb",
        "name": "delete",
        "order": 7,
        "width": "2",
        "height": "1",
        "passthru": false,
        "label": "delete",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "delete",
        "payload": "delete",
        "topic": "topic",
        "topicType": "msg",
        "x": 670,
        "y": 500,
        "id": "4636da6271a079aa",
        "label": "انتخاب افکت ",
        "tooltip": "",
        "order": 5,
        "width": "9",
        "height": 1,
        "passthru": true,
        "multiple": true,
        "options": [
                "label": "افکت اول",
                "value": "A",
                "type": "str"
                "label": "افکت دوم",
                "value": "B",
                "type": "str"
                "label": "افکت سوم",
                "value": "C",
                "type": "str"
                "label": "افکت چهارم",
                "value": "D",
                "type": "str"
                "label": "افکت پنجم",
                "value": "E",
                "type": "str"
                "label": "افکت ششم",
                "value": "F",
                "type": "str"
        "payload": "",
        "topic": "effect",
        "topicType": "str",
        "className": "",
        "x": 660,
        "y": 340,
                "81363a2d27fbc7c3"
        "id": "6305d8128da6cbab",
        "type": "ui_group",
        "name": "Group 1",
        "tab": "b927390ff1bafb51",
        "order": 1,
        "disp": true,
        "width": 17
        "id": "b927390ff1bafb51",
        "type": "ui_tab",
        "name": "bridge",
        "icon": "dashboard",
        "order": 20,
        "disabled": false,
        "hidden": false
Here is an example for you
[{"id":"81363a2d27fbc7c3","type":"function","z":"36348c32365b6b66","name":"Format for Table","func":"let output  = flow.get(\"table\") || [];\nif(output.length > 0){\n    output.push(msg.payload)\n    msg.payload={\n    command:\"cleardata\",\n    arguments: []\n    }\n    node.send(msg);\n    msg.payload = output;\n}else{\n    output = [msg.payload];\n    msg.payload = output;\n    msg.ui_control = {\n        \"tabulator\": {\n            pagination:\"local\",\n            paginationSize:8,\n            paginationButtonCount:2,\n            selectable:1,\n            locale:true,\n            columns:[\n                {\n                    title:\"year\", \n                    field:\"year\", \n                    editor:\"textarea\", \n                    editorParams:{\n                        elementAttributes:{\n                            maxlength:\"4\", //set the maximum character length of the textarea element to 10 characters\n                        },\n                    mask:\"9999\",\n                    verticalNavigation:\"editor\", //navigate cursor around text area without leaving the cell\n                    }\n                },\n                {\n                    title:\"start\", \n                    field:\"startTime\", \n                    editor:\"textarea\", \n                    editorParams:{\n                        elementAttributes:{\n                            maxlength:\"24\", //set the maximum character length of the textarea element to 10 characters\n                        },\n                    mask:\"9999-99-99T99:99:99.999X\",\n                    verticalNavigation:\"editor\", //navigate cursor around text area without leaving the cell\n                    },\n                    formatter:\"datetime\", formatterParams:{\n                        inputFormat:\"YYYY-MM-DDTHH:mm:ss.SSSZ\",\n                        outputFormat:\"HH:mm\",\n                        invalidPlaceholder:\"(invalid date)\"\n                    }\n                }\n            ]                  \n        }\n    }\n}\n\nflow.set(\"table\", output)\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":1260,"y":240,"wires":[["0122d72eabb1d981"]]},{"id":"23129760f0c4b11b","type":"switch","z":"36348c32365b6b66","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"time","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1090,"y":240,"wires":[["81363a2d27fbc7c3"]]},{"id":"0122d72eabb1d981","type":"ui_table","z":"36348c32365b6b66","group":"6305d8128da6cbab","name":"زمانبندی ","order":6,"width":"7","height":"5","columns":[],"outputs":1,"cts":true,"x":1430,"y":240,"wires":[["519451eb7f733ded"]]},{"id":"852b755121295677","type":"join","z":"36348c32365b6b66","name":"","mode":"custom","build":"merged","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"6","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":950,"y":240,"wires":[["23129760f0c4b11b"]]},{"id":"542e50cbd3a89474","type":"change","z":"36348c32365b6b66","name":"","rules":[],"action":"","property":"","from":"","to":"","reg":false,"x":1125,"y":600,"wires":[["0122d72eabb1d981"]],"l":false},{"id":"519451eb7f733ded","type":"change","z":"36348c32365b6b66","name":"","rules":[{"t":"set","p":"table[msg.row]","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1630,"y":240,"wires":[["99aa178ef64a181f","e7d13f431b77f891"]]},{"id":"b952f36f30a14385","type":"ui_form","z":"36348c32365b6b66","name":"Schedule Form","label":"","group":"6305d8128da6cbab","order":4,"width":"9","height":"2","options":[{"label":"Start Time (HH:MM)","value":"startTime","type":"time","required":true,"rows":null},{"label":"Finish Time (HH:MM)","value":"finishTime","type":"time","required":true,"rows":null}],"formValue":{"startTime":"","finishTime":""},"payload":"{}","submit":"submit","cancel":"","topic":"time","topicType":"str","splitLayout":false,"className":"","x":600,"y":340,"wires":[["b952f36f30a14385","852b755121295677"]]},{"id":"d00d9395cf1023d8","type":"change","z":"36348c32365b6b66","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload[msg.topic]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":160,"wires":[["852b755121295677"]]},{"id":"edde555c4528ab75","type":"change","z":"36348c32365b6b66","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload[msg.topic]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":220,"wires":[["852b755121295677"]]},{"id":"a78e7a590ed98f4b","type":"change","z":"36348c32365b6b66","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload[msg.topic]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":790,"y":280,"wires":[["852b755121295677"]]},{"id":"c684374447ef974c","type":"change","z":"36348c32365b6b66","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload[msg.topic]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":790,"y":400,"wires":[["852b755121295677"]]},{"id":"6942ac8b44537121","type":"change","z":"36348c32365b6b66","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"command\":\"clearData\",\"arguments\":[],\"returnPromise\":true}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":580,"wires":[["542e50cbd3a89474"]]},{"id":"aefbe66849040dc1","type":"change","z":"36348c32365b6b66","name":"","rules":[{"t":"delete","p":"table[msg.topic]","pt":"flow"},{"t":"set","p":"payload","pt":"msg","to":"table","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":620,"wires":[["542e50cbd3a89474"]]},{"id":"99aa178ef64a181f","type":"debug","z":"36348c32365b6b66","name":"debug 8","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1660,"y":180,"wires":[]},{"id":"e7d13f431b77f891","type":"change","z":"36348c32365b6b66","name":"","rules":[],"action":"","property":"","from":"","to":"","reg":false,"x":385,"y":500,"wires":[["209d239d96790a14","ddcb21a64ebe5251"]],"l":false},{"id":"152bce1c24dfcab7","type":"ui_dropdown","z":"36348c32365b6b66","name":"","label":"انتخاب سال ","tooltip":"","place":"Select option","group":"6305d8128da6cbab","order":1,"width":"9","height":"1","passthru":true,"multiple":false,"options":[{"label":"1402","value":"1402","type":"str"},{"label":"1403","value":"1403","type":"str"},{"label":"1404","value":"1404","type":"str"},{"label":"1405","value":"1405","type":"str"},{"label":"1406","value":"1406","type":"str"},{"label":"1407","value":"1407","type":"str"},{"label":"1408","value":"1408","type":"str"},{"label":"1409","value":"1409","type":"str"},{"label":"1410","value":"1410","type":"str"}],"payload":"","topic":"year","topicType":"str","className":"","x":580,"y":160,"wires":[["d00d9395cf1023d8"]]},{"id":"f82d933954275f0d","type":"ui_dropdown","z":"36348c32365b6b66","name":"","label":"انتخاب ماه ","tooltip":"","place":"Select option","group":"6305d8128da6cbab","order":2,"width":"9","height":1,"passthru":true,"multiple":false,"options":[{"label":"فروردین ","value":"1","type":"str"},{"label":"اردیبهشت ","value":"2","type":"str"},{"label":"خرداد","value":"3","type":"str"},{"label":"تیر ","value":"4","type":"str"},{"label":"مرداد","value":"5","type":"str"},{"label":"شهریور","value":"6","type":"str"},{"label":"مهر","value":"7","type":"str"},{"label":"آبان ","value":"8","type":"str"},{"label":"آذر","value":"9","type":"str"},{"label":" دی ","value":"10","type":"str"},{"label":"بهمن ","value":"11","type":"str"},{"label":"اسفند ","value":"12","type":"str"}],"payload":"","topic":"month","topicType":"str","className":"","x":580,"y":220,"wires":[["edde555c4528ab75"]]},{"id":"9d3aed3a25d93d3f","type":"ui_dropdown","z":"36348c32365b6b66","name":"","label":"انتخاب روز از ماه","tooltip":"","place":"Select option","group":"6305d8128da6cbab","order":3,"width":"9","height":1,"passthru":true,"multiple":false,"options":[{"label":"","value":"1","type":"str"},{"label":"","value":"2","type":"str"},{"label":"","value":"3","type":"str"},{"label":"","value":"4","type":"str"},{"label":"","value":"5","type":"str"},{"label":"","value":"6","type":"str"},{"label":"","value":"7","type":"str"},{"label":"","value":"8","type":"str"},{"label":"","value":"9","type":"str"},{"label":"","value":"10","type":"str"},{"label":"","value":"11","type":"str"},{"label":"","value":"12","type":"str"},{"label":"","value":"13","type":"str"},{"label":"","value":"14","type":"str"},{"label":"","value":"15","type":"str"},{"label":"","value":"16","type":"str"},{"label":"","value":"17","type":"str"},{"label":"","value":"18","type":"str"},{"label":"","value":"19","type":"str"},{"label":"","value":"20","type":"str"},{"label":"","value":"21","type":"str"},{"label":"","value":"22","type":"str"},{"label":"","value":"23","type":"str"},{"label":"","value":"24","type":"str"},{"label":"","value":"25","type":"str"},{"label":"","value":"26","type":"str"},{"label":"","value":"27","type":"str"},{"label":"","value":"28","type":"str"},{"label":"","value":"29","type":"str"},{"label":"","value":"30","type":"str"},{"label":"","value":"31","type":"str"}],"payload":"","topic":"day","topicType":"str","className":"","x":600,"y":280,"wires":[["a78e7a590ed98f4b"]]},{"id":"4636da6271a079aa","type":"ui_dropdown","z":"36348c32365b6b66","name":"","label":"انتخاب افکت ","tooltip":"","place":"Select option","group":"6305d8128da6cbab","order":5,"width":"9","height":1,"passthru":true,"multiple":true,"options":[{"label":"افکت اول","value":"A","type":"str"},{"label":"افکت دوم","value":"B","type":"str"},{"label":"افکت سوم","value":"C","type":"str"},{"label":"افکت چهارم","value":"D","type":"str"},{"label":"افکت پنجم","value":"E","type":"str"},{"label":"افکت ششم","value":"F","type":"str"}],"payload":"","topic":"effect","topicType":"str","className":"","x":590,"y":400,"wires":[["c684374447ef974c"]]},{"id":"173c5b48f0691e92","type":"trigger","z":"36348c32365b6b66","name":"","op1":"","op2":"","op1type":"pay","op2type":"pay","duration":"250","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":800,"y":600,"wires":[["6942ac8b44537121"],["aefbe66849040dc1"]]},{"id":"209d239d96790a14","type":"change","z":"36348c32365b6b66","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"row","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":600,"wires":[["3e440484554451cb"]]},{"id":"ddcb21a64ebe5251","type":"change","z":"36348c32365b6b66","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":480,"wires":[["3bbb7dec5e635afb"]]},{"id":"3e440484554451cb","type":"ui_button","z":"36348c32365b6b66","name":"delete","group":"6305d8128da6cbab","order":7,"width":"2","height":"1","passthru":false,"label":"delete","tooltip":"","color":"","bgcolor":"","className":"","icon":"delete","payload":"delete","payloadType":"str","topic":"topic","topicType":"msg","x":650,"y":600,"wires":[["173c5b48f0691e92"]]},{"id":"3bbb7dec5e635afb","type":"ui_button","z":"36348c32365b6b66","name":"send","group":"6305d8128da6cbab","order":8,"width":"2","height":"1","passthru":false,"label":"send","tooltip":"","color":"","bgcolor":"","className":"","icon":"send","payload":"send","payloadType":"str","topic":"topic","topicType":"msg","x":650,"y":480,"wires":[["64111139177da2aa"]]},{"id":"64111139177da2aa","type":"change","z":"36348c32365b6b66","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"topic","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"send","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":480,"wires":[["4902a8d8524fc537"]]},{"id":"4902a8d8524fc537","type":"debug","z":"36348c32365b6b66","name":"debug 2476","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1230,"y":460,"wires":[]},{"id":"6305d8128da6cbab","type":"ui_group","name":"Group 1","tab":"b927390ff1bafb51","order":1,"disp":true,"width":17},{"id":"b927390ff1bafb51","type":"ui_tab","name":"bridge","icon":"dashboard","order":20,"disabled":false,"hidden":false}]
It uses tabulator 4.7 to make fields editable, once you edit you must click on row to store edit.
You will need to add more info to columns in function node, if you want more editable fields.
Click on row to load the send and delete, then click send or delete.
I have also edited yor dashboard, all six items must be filled before submit will do anything.
I also added selectable row and pagination to table for you.
There are more examples for ui-table in import > examples > ui-table.
Hope it helps
