The same flow I have posted which is giving the deploy failed message:
[{"id":"2867501b.43456","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"560199de.cdcaf8","type":"mysql","z":"2867501b.43456","mydb":"2a44bcb3.ad6994","name":"","x":550,"y":180,"wires":[["6d7e9abd.a213b4"]]},{"id":"6d7e9abd.a213b4","type":"debug","z":"2867501b.43456","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":750,"y":180,"wires":},{"id":"845ca325.9ebb2","type":"inject","z":"2867501b.43456","name":"","topic":"","payload":"{"message":"Foo"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":180,"wires":[["7303633e.cac12c"]]},{"id":"7303633e.cac12c","type":"function","z":"2867501b.43456","name":"","func":"msg.topic = "INSERT INTO aress_test (message) VALUES (?);"\nmsg.payload=[msg.payload.message];\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":180,"wires":[["560199de.cdcaf8"]]},{"id":"2a44bcb3.ad6994","type":"MySQLdatabase","z":"","host":"localhost","port":"3306","db":"AressSensorData","tz":""}]
If we use any other query except the INSERT in the Function node in the given flow, the deployment will be successful.
