"Deploy failed: no response from server"
I have Node Red running for a year or something, but now have the problem that I can not add anything anymore, I always receive the message "Deploy failed: no response from server" after deployment.
When I deploy it without changing anything, it works. When I disable all the flows except one flow, the problem is stilll there. I have it running in Docker, latest version 1.3.5. I can not see anything in the Event log, I think it is because it is running in Docker.
Anyone is having any idea?
Kind regards.
It looks that there is a maximum number of nodes? When I remove two debug nodes from a flow, I can add two more on another flow with successfull deployment. When I add three instead of two, some error occurs.
