Hi All, I've deployed node red to azure cluster and want to access flow.json file from external storage like aws s3 bucket or azure blob, could you tell me how can I access flow file from external storage and deploy my flows.
You can use a storage plugin for that purpose.
With 'node-red-mongo-storage-plugin' all nodes will be saved on a MongoDB Database.
Note that using this solution, the 'flow.json' will not be used at all.
Search for a storage plugin that suits you.
