Deploy Node-RED to Heroku
Hi all,
I further figured out about the files included in the Github repo that used to connect to the Heroku server and substituted with my own package.json, flow .json, repo link in app.json. After deploying again, I received an error from the logs window of Heroku CLI as below:
2021-04-13T10:22:01.693823+00:00 heroku[web.1]: Starting process with command `node --max-old-space-size=384 node_modules/node-red/red.js --settings ./settings.js --userDir ./`
2021-04-13T10:22:05.304911+00:00 heroku[web.1]: Process exited with status 1
2021-04-13T10:22:05.411606+00:00 heroku[web.1]: State changed from starting to crashed
2021-04-13T10:22:05.185465+00:00 app[web.1]: internal/modules/cjs/loader.js:883
2021-04-13T10:22:05.185490+00:00 app[web.1]: throw err;
2021-04-13T10:22:05.185491+00:00 app[web.1]: ^
2021-04-13T10:22:05.185492+00:00 app[web.1]: Error: Cannot find module '/app/node_modules/node-red/red.js'
2021-04-13T10:22:05.185492+00:00 app[web.1]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
2021-04-13T10:22:05.185492+00:00 app[web.1]: at Function.Module._load (internal/modules/cjs/loader.js:725:27)
2021-04-13T10:22:05.185493+00:00 app[web.1]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
2021-04-13T10:22:05.185494+00:00 app[web.1]: at internal/main/run_main_module.js:17:47 {
2021-04-13T10:22:05.185494+00:00 app[web.1]: code: 'MODULE_NOT_FOUND',
2021-04-13T10:22:05.185495+00:00 app[web.1]: requireStack: []
2021-04-13T10:22:05.185495+00:00 app[web.1]: }
My Github repo link
Hope to get your help. Thank you.
Try to update your procfile. This worked for us:
node-red --settings ./.node-red/settings.js --userDir ./.node-red
