I found this example and will pick it up tomorrow.
[{"id":"a3ad21bb.8e08a8","type":"ui_template","z":"ef05418d.df1618","group":"ada4e0c8.ca2d58","name":"","order":0,"width":0,"height":0,"format":"<h3>Testing template</h3>\n<p>{{msg.payload}}</p>\n<script>\n(function() {\n var count = 0\n function testit(msg,scope) {\n count = count+1;\n console.log(\"In testit \" + msg.payload + \" count = \" + count);\n scope.send({payload: \"from testit \" + msg.payload + \" count = \" + count});\n }\n \n (function(scope) {\n scope.send({payload: \"preload\"}); // this gets sent when the view is opened in the browser\n scope.$watch('msg', function(msg) {\n if (msg) {\n testit(msg, scope);\n }\n });\n })(scope);\n})();\n</script>","storeOutMessages":false,"fwdInMessages":false,"x":353.5,"y":145,"wires":[["89d9b60a.9b44e8"]]},{"id":"9d387518.22ba48","type":"inject","z":"ef05418d.df1618","name":"","topic":"","payload":"One","payloadType":"str","repeat":"","crontab":"","once":false,"x":136.5,"y":145,"wires":[["a3ad21bb.8e08a8"]]},{"id":"88c9b5ce.ba0f08","type":"ui_template","z":"ef05418d.df1618","group":"ada4e0c8.ca2d58","name":"","order":0,"width":0,"height":0,"format":"<h3>Testing template</h3>\n<p>{{msg.payload}}</p>\n<script>\n(function() {\n var count = 0\n function testit(msg,scope) {\n count = count+1;\n console.log(\"In testit \" + msg.payload + \" count = \" + count);\n scope.send({payload: \"from testit \" + msg.payload + \" count = \" + count});\n }\n \n (function(scope) {\n scope.send({payload: \"preload\"}); // this gets sent when the view is opened in the browser\n scope.$watch('msg', function(msg) {\n if (msg) {\n testit(msg, scope);\n }\n });\n })(scope);\n})();\n</script>","storeOutMessages":false,"fwdInMessages":false,"x":354,"y":257,"wires":[["aece47ab.d4951"]]},{"id":"3f711b15.d883c4","type":"inject","z":"ef05418d.df1618","name":"","topic":"","payload":"Two","payloadType":"str","repeat":"","crontab":"","once":false,"x":135,"y":258,"wires":[["88c9b5ce.ba0f08"]]},{"id":"89d9b60a.9b44e8","type":"debug","z":"ef05418d.df1618","name":"","active":true,"console":"false","complete":"false","x":562.5,"y":145,"wires":[]},{"id":"aece47ab.d4951","type":"debug","z":"ef05418d.df1618","name":"","active":true,"console":"false","complete":"false","x":566.5,"y":257,"wires":[]},{"id":"ada4e0c8.ca2d58","type":"ui_group","z":"ef05418d.df1618","name":"Default","tab":"e4c8df5a.bc9048","disp":true,"width":"6"},{"id":"e4c8df5a.bc9048","type":"ui_tab","z":"ef05418d.df1618","name":"tab2","icon":"dashboard"}]
