Different alignments of columns in v-data-table
I've just started to use Dashboard 2.0 with th v-data-table component.
I have a simple table with two columns. First column displays labels and should be left-aligned. The second column displays numerical values and should be right-aligned.
This construct in ui-template has no effect:
        headers: [
          { text: 'Speicher', value: 'speicher', align: 'left' },
          { text: 'Wert', value: 'wert', align: 'right' },
The following styling aligns both columns
.v-data-table__tr {
   text-align: right;
Can you pls. recommend a way to align both columns in a different way.
regards
Juergen
I don't know the answer to your question, but is there a reason you are not using the ui-table node for this? You can specify the alignment for each column in that node.
Looking at the Vuetify website regarding the data table align
If you look at the Script tab it has an example
 headers: [
        { title: 'Plant', align: 'start', sortable: false, key: 'name' },
        { title: 'Light', align: 'end', key: 'light' },
        { title: 'Height', align: 'end', key: 'height' },
        { title: 'Pet Friendly', align: 'end', key: 'petFriendly' },
        { title: 'Price ($)', align: 'end', key: 'price' },
So try align: 'start' or align: 'end' instead of left, right
I have tried this too (start, end) but without effect.
I'm using dashboard 2.0 and there is another table component with a different styling available.
Sorry, I don't understand what you mean. The dashboard 2 table node supports column alignment.
Correct. But I want to style other properties like color of values and therefore I use a template node instead of the table node. Perhaps this is not a good approach. I'm open for recommendations.
OK, that makes sense.
I use v-virtual-scroll as container for v-list-items
It does give enough slots for prepend and append elements if needed so defenetely enough for two column text content. No need for all fancy bells and whistles the table component brings in.
And easy enough to write some css to manage layout and colors or whatever needed.
In addition to the Vuetify table or the dashboard's built-in table node, another option for you is to use @omrid01/node-red-dashboard-2-table-tabulator, which gives you full control of formatting (incl. conditional formatting),
I also tried the example from the Vuetify docs in Dashboard 2 ui-template and for me the table column alignment works fine.
Test Flow :
[{"id":"918909f9b7d815c0","type":"ui-template","z":"54efb553244c241f","group":"920b4bf313db45d0","page":"","ui":"","name":"","order":1,"width":0,"height":0,"head":"","format":"<template>\n    <v-data-table :headers=\"headers\" :items=\"plants\" density=\"compact\" item-key=\"name\"></v-data-table>\n</template>\n\n<script>\nexport default {\n    data() {\n      \n    return {\n      headers: [\n        { title: 'Plant', align: 'start', sortable: false, key: 'name' },\n        { title: 'Light', align: 'start', key: 'light' },\n        { title: 'Height', align: 'end', key: 'height' },\n        { title: 'Pet Friendly', align: 'end', key: 'petFriendly' },\n        { title: 'Price ($)', align: 'end', key: 'price' },\n      ],\n      plants: [\n        {\n          name: 'Fern',\n          light: 'Low',\n          height: '20cm',\n          petFriendly: 'Yes',\n          price: 20,\n        },\n        {\n          name: 'Snake Plant',\n          light: 'Low',\n          height: '50cm',\n          petFriendly: 'No',\n          price: 35,\n        },\n        {\n          name: 'Monstera',\n          light: 'Medium',\n          height: '60cm',\n          petFriendly: 'No',\n          price: 50,\n        },\n        {\n          name: 'Pothos',\n          light: 'Low to medium',\n          height: '40cm',\n          petFriendly: 'Yes',\n          price: 25,\n        },\n        {\n          name: 'ZZ Plant',\n          light: 'Low to medium',\n          height: '90cm',\n          petFriendly: 'Yes',\n          price: 30,\n        },\n        {\n          name: 'Spider Plant',\n          light: 'Bright, indirect',\n          height: '30cm',\n          petFriendly: 'Yes',\n          price: 15,\n        },\n        {\n          name: 'Air Plant',\n          light: 'Bright, indirect',\n          height: '15cm',\n          petFriendly: 'Yes',\n          price: 10,\n        },\n        {\n          name: 'Peperomia',\n          light: 'Bright, indirect',\n          height: '25cm',\n          petFriendly: 'Yes',\n          price: 20,\n        },\n        {\n          name: 'Aloe Vera',\n          light: 'Bright, direct',\n          height: '30cm',\n          petFriendly: 'Yes',\n          price: 15,\n        },\n        {\n          name: 'Jade Plant',\n          light: 'Bright, direct',\n          height: '40cm',\n          petFriendly: 'Yes',\n          price: 25,\n        },\n      ],\n   \n  \n    }\n        },\n        watch: {\n            // watch for any changes of \"msg\"\n            msg: function () {\n             \n            }\n        },\n        \n       \n       \n    }\n</script>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":420,"y":3880,"wires":[[]]},{"id":"920b4bf313db45d0","type":"ui-group","name":"Group 1","page":"4491a49c6b49a6b3","width":6,"height":1,"order":1,"showTitle":true,"className":"","visible":true,"disabled":false,"groupType":"default"},{"id":"4491a49c6b49a6b3","type":"ui-page","name":"Page 1","ui":"dca6aa0ee8b1020c","path":"/page1","icon":"home","layout":"grid","theme":"2ce3f65dd0354f9c","breakpoints":[{"name":"Default","px":0,"cols":3},{"name":"Tablet","px":576,"cols":6},{"name":"Small Desktop","px":768,"cols":9},{"name":"Desktop","px":1024,"cols":12}],"order":1,"className":"","visible":"true","disabled":"false"},{"id":"dca6aa0ee8b1020c","type":"ui-base","name":"My Dashboard","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":true,"notificationDisplayTime":1,"showDisconnectNotification":true},{"id":"2ce3f65dd0354f9c","type":"ui-theme","name":"Default Theme","colors":{"surface":"#ffffff","primary":"#0094CE","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
Can you share your flow with some sample data to see if there are any differences ?
Thank you very much!
I've installed the node and it looks promising for my purpose.
I still have some problems to define the data structure in the node. It's an array of objects (key-value pairs) in msg.payload. I want to use the table only to display formatted data.
Regards Juergen
I still don't know how to send or format the incoming data. This input does not work:
 "data": [{"speicher":"msg.payload.speicher[]","wert":"msg.payload.wert[]"}]
The incoming data are
[{"speicher":"Ladestand (%)","wert":54},{"speicher":"Ladung Speicher (W)","wert":248},{"speicher":"Lieferung Netz (W)","wert":-215},{"speicher":"PV-Erzeugung Haus (W)","wert":495},{"speicher":"PV-Erzeugung Carport (W)","wert":266},{"speicher":"PV-Erzeugung gesamt (W)","wert":761},{"speicher":"Verbrauch (W)","wert":718}]
Can you send a sample flow?
Thank you.
Flow is attached.
flows.json (3.9 KB)
Looking at your flow, I'm still puzzled why use template/v-data-table instead of using available dashboard table nodes, but anyway:
I always prefer to keep things simple, so instead of playing with mustache trickery I just take the incoming data, format it as needed and then update the table.
<template>
    <v-data-table
      :items="items"
      :hide-default-footer="true"
      class="elevation-1"
    ></v-data-table>
</template>
<script>
  export default {
    data () {
      return {
        items: []
For example, in your flow, you mention you want to:
<!-- Add a custom suffix to the value for the "wert" column -- >
So in your script, just format the incoming msg data as needed:
const data = msg.payload;
for (let i = 0 ; i < data.length ; i++)
   data[i].wert += (":suffix"+i);
this.items = data;
Result:
