Different font style of ui-text and ui-switch
Hi there,
I have a problem with ui-text and ui-switch. The font styles are different. I have a CSS style for both and defined the text color white, but the ui-switch is gray or white transparency.
Here is a screeshot. Test is groupname. Text is ui-text. Switch is ui-switch.
This is how I defined the CSS style.
.text-neu label {
    color: white;
.text-neu span{
    color: rgb(255, 255, 255);
Can anyone help?
Try set the opacity
opacity:1;
Yes opacity is the solution. Now it works.
.text-neu label {
    color: white;
    opacity: 1;
.text-neu span{
