I am a complete newbie using Node-RED but have been working on what seemed a rather simple project for a couple of weeks now, and I am stuck. I am trying to monitor the status of a series of variables across multiple ESP32-based devices using HTTP GET. I also want to be able to send values to all or specific devices using HTTP POST. So far, the GET part is working perfectly for me, I can read the status of the different devices. I am stuck with the POST part. This is what I have:
I have two text inputs, each one accepts a number that is later combined in a single payload as the variables I want to post: "source" and "code". A payload looks something like this:
{"source":30,"code":62005}
The source value indicates to what device the post will go, say source 10, will send the code 3 to a device located in IP 192.168.0.10. What I cant seem to find is a way to change the IP address in the HTTP Request node so it is based on the source value I entered. Any ideas?
This is my flow (hopefully I am sharing the code correctly):
"id": "dbbd9ac25d0245b7",
"type": "change",
"z": "af973086eb22abf7",
"rules": [
"t": "set",
"p": "temp",
"pt": "msg",
"to": "payload",
"tot": "msg"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{}",
"tot": "json"
"t": "set",
"p": "payload.source",
"pt": "msg",
"to": "replySource",
"tot": "flow"
"t": "set",
"p": "payload.code",
"pt": "msg",
"to": "replyCode",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 720,
"y": 100,
"140f5851a4127af4"
"id": "8a53079e89f84ec9",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 1150,
"y": 40,
"id": "b3864866e9cd631c",
"type": "ui_text_input",
"name": "replySource",
"label": "Source",
"tooltip": "",
"group": "dfc9abd922154e9a",
"order": 3,
"width": 0,
"height": 0,
"passthru": true,
"mode": "number",
"delay": "0",
"topic": "",
"sendOnBlur": true,
"className": "",
"topicType": "str",
"x": 230,
"y": 60,
"ebdfa45c02f8ea4a"
"id": "36d4bdfbad777b18",
"name": "replyCode",
"label": "Code",
"tooltip": "",
"order": 2,
"width": 0,
"height": 0,
"passthru": true,
"mode": "number",
"delay": "0",
"topic": "",
"sendOnBlur": true,
"className": "",
"topicType": "str",
"x": 230,
"y": 160,
"149b45117cbb284e"
"id": "140f5851a4127af4",
"type": "ui_button",
"name": "btnSend",
"order": 4,
"width": 0,
"height": 0,
"passthru": false,
"label": "Send",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "",
"payload": "",
"payloadType": "json",
"topic": "payload",
"topicType": "msg",
"x": 920,
"y": 100,
"eea42f6c187ac0fc"
"id": "149b45117cbb284e",
"type": "change",
"rules": [
"t": "set",
"p": "replyCode",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 450,
"y": 160,
"dbbd9ac25d0245b7"
"id": "ebdfa45c02f8ea4a",
"type": "change",
"rules": [
"t": "set",
"p": "replySource",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 460,
"y": 60,
"dbbd9ac25d0245b7"
"id": "eea42f6c187ac0fc",
"type": "http request",
"method": "POST",
"ret": "txt",
"paytoqs": "ignore",
"url": "192.168.0.157/reply",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"senderr": false,
"credentials": {},
"x": 1150,
"y": 100,
"id": "dfc9abd922154e9a",
"type": "ui_group",
"name": "InputCommand",
"tab": "e562a4a.39a9e58",
"order": 4,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "e562a4a.39a9e58",
"type": "ui_tab",
"name": "Non-myth of the Noble Red's Dashboard",
"icon": "dashboard",
"order": 1,
"disabled": false,
"hidden": false
