Hi everyone. I have two variables entered by the user using text input. Let's call them variables A and B. Based on the value entered in Variable A, I have a function that sets a specific IP address as msg.url for HTTP request (POST). For instance, if the value A is 10, then the IP address defined in the function would be 192.168.0.10. In the payload of this request, structured as JSON are both variables A (10) and B (whatever other number the user enters).
I want the variables sent to the IP upon pressing a button. I have a change node that combines the variable in the payload and sets the msg.url. However, as you probably know, the button only sends the payload, so the . How can I send the IP of the request when the button is pressed? Any help will be very much appreciated.
Below the code.
[{"id":"dbbd9ac25d0245b7","type":"change","z":"af973086eb22abf7","name":"","rules":[{"t":"set","p":"temp","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"{}","tot":"json"},{"t":"set","p":"payload.source","pt":"msg","to":"replySource","tot":"flow"},{"t":"set","p":"payload.code","pt":"msg","to":"replyCode","tot":"flow"},{"t":"set","p":"url","pt":"msg","to":"url","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":200,"wires":[["fac0982110da23a1"]]},{"id":"8a53079e89f84ec9","type":"debug","z":"af973086eb22abf7","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1330,"y":140,"wires":[]},{"id":"b3864866e9cd631c","type":"ui_text_input","z":"af973086eb22abf7","name":"replySource","label":"Source","tooltip":"","group":"dfc9abd922154e9a","order":3,"width":0,"height":0,"passthru":true,"mode":"number","delay":"300","topic":"","sendOnBlur":true,"className":"","topicType":"str","x":330,"y":160,"wires":[["ebdfa45c02f8ea4a"]]},{"id":"36d4bdfbad777b18","type":"ui_text_input","z":"af973086eb22abf7","name":"replyCode","label":"Code","tooltip":"","group":"dfc9abd922154e9a","order":2,"width":0,"height":0,"passthru":true,"mode":"number","delay":"300","topic":"","sendOnBlur":true,"className":"","topicType":"str","x":330,"y":260,"wires":[["149b45117cbb284e"]]},{"id":"149b45117cbb284e","type":"change","z":"af973086eb22abf7","name":"","rules":[{"t":"set","p":"replyCode","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":260,"wires":[["dbbd9ac25d0245b7"]]},{"id":"ebdfa45c02f8ea4a","type":"change","z":"af973086eb22abf7","name":"","rules":[{"t":"set","p":"replySource","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":160,"wires":[["dbbd9ac25d0245b7","008fea195280df1e"]]},{"id":"eea42f6c187ac0fc","type":"http request","z":"af973086eb22abf7","name":"","method":"POST","ret":"txt","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":1330,"y":200,"wires":[[]]},{"id":"5fed2ff93e374d2a","type":"change","z":"af973086eb22abf7","name":"","rules":[{"t":"set","p":"url","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":120,"wires":[["dbbd9ac25d0245b7"]]},{"id":"008fea195280df1e","type":"function","z":"af973086eb22abf7","name":"","func":"var replySourceVal = flow.get('replySource');\n\nif (replySourceVal == \"10\") {\nmsg.payload = \"192.168.0.10/reply\";\n}\nif (replySourceVal == \"20\") {\nmsg.payload = \"192.168.0.20/reply\";\n}\nif (replySourceVal == \"30\") {\nmsg.payload = \"192.168.0.30/reply\";\n}\nif (replySourceVal == \"01\") {\nmsg.payload = \"192.168.0.101/reply\";\n}\nif (replySourceVal == \"02\") {\nmsg.payload = \"192.168.0.102/reply\";\n}\nif (replySourceVal == \"03\") {\nmsg.payload = \"192.168.0.103/reply\";\n}\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":800,"y":120,"wires":[["5fed2ff93e374d2a"]]},{"id":"be2bd6f7160e0d78","type":"debug","z":"af973086eb22abf7","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"url","targetType":"msg","statusVal":"","statusType":"auto","x":1320,"y":260,"wires":[]},{"id":"fac0982110da23a1","type":"ui_button","z":"af973086eb22abf7","name":"","group":"dfc9abd922154e9a","order":2,"width":0,"height":0,"passthru":false,"label":"Send","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"","payloadType":"json","topic":"topic","topicType":"msg","x":1130,"y":200,"wires":[["8a53079e89f84ec9","eea42f6c187ac0fc","be2bd6f7160e0d78"]]},{"id":"dfc9abd922154e9a","type":"ui_group","name":"InputCommand","tab":"e562a4a.39a9e58","order":4,"disp":true,"width":"6","collapse":false,"className":""},{"id":"e562a4a.39a9e58","type":"ui_tab","name":"Non-myth of the Noble Red's Dashboard","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
