Different Set of Flows at Each Reboot
Looking for a bit of guidance here. I have an Ubuntu server running Node-Red. Each time I reboot it, I seem to randomly get one or the other, set of Flows.
For example, before reboot I have the following flows:
_Default , Site1, Site2, Testing
After reboot
_Default , Flow1, Flow2
The second set of flows, is recognizable and has elements I DID add at one point, but was a long time ago.
I would guess Node-Red is somehow loading a flows.json and then saying, yep im done. But then other reboots it loads the first set of flows as desired.
How do I control which set of flows get loaded?
I just noticed too, that on the first set I show NodeRed at v1.0.3.
On the second set I have NodeRed at v1.0.6
two possibilities
  1. you are running as a different user so picking up a different Node-RED install and flow
  2. your computer is changing hostname (maybe via dhcp but this doesn't usually happen on ubuntu) - and so picking up a different flow in ~/.node-red .
Thank you, I figured it out. At some point I must have installed Node-Red with Snap package manger. SO you are correct, two Node-Reds were running, one at 1.06 and one via the npm.
sudo snap list was able to show me the installed Node-Red instance via snap.
Sudo snap remove node-red removed that install.
