Directing several flows in 1 function node
Just a question in my project i'm sending several inputs into 1 function node. (or is it discouraged?)
It works but i'm wondering how node red handles this? Is it's storing all the flows at the beginning and treats it one at a time or are all the flows treated at the same time in parrallel?
And if it's handles the flows 1 at a time, what's the max storage of the flows before? (guessing the system memory).
Thanks at advance!
Kind regards,
Ward
Your terminology is a bit mixed up.
Whats happening is each time a message object (msg) is emitted from a node (e.g. from your green nodes on the left), they travel down the wires and are operated on by the nodes they flow to/through.
The code in the last function simply does its thing everytime a msg hits it.
That mostly depends on what you are doing in the function nodes. But no, this is a perfectly legitimate setup and use of nodes.
The messages are kinda serial as in they travel down the wires singularly (nodejs is single threaded) and unless you have a HUGE number of msgs travelling down the wires, you are unlikely to be facing any issues. (I have no details on what that HUGE number would be - possibly memory limited)
@Steve-Mcl thanks for the quick reply.
I've got to work on that :sweat_smile: :wink:
But now i know for certain it's never gonna drop a msg if the node is busy.
