Hi folks,
I have created some tabsheets in the config screen of a custom node:
node.tabs = RED.tabs.create({
node.tabs.addTab({
label: "Chart"
Is it somehow possible to disable those tabsheets afterwards?
Tried a couple of this (like e.g. this) but don't get it running...
Thanks !!
Bart
Hi @BartButenaers,
the RED.tabs component is a custom component created for Node-RED. It has nothing to do with the jQuery UI Tabs component.
There is no api for disabling a tab (by which I assume you mean leave the tab in place, but don't let the user select it) - it isn't a feature we've needed in the core of Node-RED so no code has been written to support it.
You can fully remove a tab using node.tabs.removeTab("node-plotly-tab-chart");
Hi Nick,
welcome back.
Ok then I will workaround it by removing the tab instead of disabling it.
Thanks!
