I have a set of nodes that, depending on some events, make a button enabled or disabled (sending msg.enabled=true/false). This state is sent to the button every 3 seconds. There is also an event that should enable or disable the same button for 10 seconds, while the previous trigger should not change this state. How can I implement this?
Welcome to the forum @IvanPoluda.
You could use a Trigger node in combination with a node-red-contrib-simple-gate. The gate node can block the regular update based on the trigger node messages, which also disable/enable the button.
Colin, thank you so much! This is exactly what I was looking for! Have a nice day!))
