Hello. Is there any way to disable Link Call timeout without pointing a catch node at it?
Context: In my flow I have to discard some messages. That's expected behaviour. However that will cause Link Call to timeout.
Is there anything that can be done?
Let the message return but set a flag in the "unwanted msg" so that it is discarded after the link call.
That wouldn't work.
I said "discard" intending to simplify my question but the message actually ends up inside a subflow and then in a http response node.
Also my idea for link call was more flow organization rather than re-usable subroutines, adding extra logic on the exit kinda defeats the point.
If you dont say what you mean we can hardly advise you properly.
To answer your question, no, you cannot "disable Link Call timeout" - but you can use a flag to discard it at the other side.
