Link Call with dynamic timeout duration
I I am looking for a way to address a link call node using dynamic timeout times.
In other words, that I can specify a value msg.timeout and this is used? Unfortunately, I haven't found a way at the moment, so I'm using a switch node as a workaround, which links to different link call nodes with a fixed timeout duration depending on the msg.timeout value.
This works, but is not really pretty.....
Have I overlooked something that could be solved more elegantly?
S.
Looking at the code for the link call node, no it's not possible to set a dynamic timeout.
But that could be "fixed" by doing something like this (warning: pseudo code):
                        }, !isNaN(parseFloat(msg.timeout)) || timeout)
at around here.
