I noticed that enabling/disabling template nodes becomes not usable if template gets some input from msg.payload
For example the following flow, uses a template to generate a list of text inputs starting from an array of labels in msg.payload.
[{"id":"51c73d95.d5dee4","type":"inject","z":"4f276a09.ba5e54","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":320,"y":180,"wires":[["7d6301b7.dd766"]]},{"id":"4ea090a1.32f02","type":"inject","z":"4f276a09.ba5e54","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":310,"y":280,"wires":[["40764ebe.e362"]]},{"id":"40764ebe.e362","type":"function","z":"4f276a09.ba5e54","name":"Set enabled property","func":"msg = {enabled:msg.payload};\nreturn msg;","outputs":1,"noerr":0,"x":520,"y":300,"wires":[["72f913cd.fd7c8c"]]},{"id":"d4372db5.efb27","type":"inject","z":"4f276a09.ba5e54","name":"","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":310,"y":320,"wires":[["40764ebe.e362"]]},{"id":"72f913cd.fd7c8c","type":"ui_template","z":"4f276a09.ba5e54","group":"a2a7a98e.efd6b8","name":"","order":4,"width":"6","height":"9","format":"<div ng-repeat=\"row in msg.payload\">\n <label>{{row}}</label>\n <input style=\"width:100%;\" ng-model-options=\"{ debounce: 200 }\" ng-model=\"i[$index]\" ng-change=\"out.payload = {val : i[$index], index : $index}; send(out)\"><br>\n</div>\n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":720,"y":180,"wires":[[]]},{"id":"7d6301b7.dd766","type":"function","z":"4f276a09.ba5e54","name":"create label array","func":"msg.payload = [\"Label1\",\"Label2\",\"Label3\"];\nreturn msg;","outputs":1,"noerr":0,"x":510,"y":180,"wires":[["72f913cd.fd7c8c"]]},{"id":"a2a7a98e.efd6b8","type":"ui_group","z":"","name":"Template group","tab":"5b337e3b.68826","order":2,"disp":true,"width":"6","collapse":false},{"id":"5b337e3b.68826","type":"ui_tab","z":"","name":"Home","icon":"home","order":1}]
When you try to dynamically enable/disable using msg.enabled = true/false, the content disappears.
I think it is related to the following quote of the dashboard documentation: ![]()
Any widget can be disabled by passing in a
msg.enabledproperty set tofalse;. Note: this doesn't stop the widget receiving messages but does stop inputs being active and does re-style the widget.
The re-style causes the template to evaluate again the message.payload, which is not present in the enable message.
Is there any way to overcome this behavior?
It doesn't seem very elegant but it should work!
