Distributed NodeRed and MQTT
Hi all,
I want to use Distributed NodeRed, in which the flow should execute on devices transparently communicating between them using the MQTT server configured in the wire node in dist-wire.js .
  • Do you know how the nodes use this 'wire node'? Which function they use?
  • It is possible to modify o replace MQTT?
Thanks in advance!
Not sure how many people here have heard or played with dnr. You may be better asking on the project github direct
Also notice that the repository you linked to says that it is discontinued and that you should refer to https://github.com/namgk/dnr-editor.
Hi @Colin, thanks for the reply.
I also used the repository you mentioned, but in that repo I din't find the 'dist' folder as in the other one(https://github.com/mblackstock/node-red-contrib/tree/experimental-dist-flows/nodes).
So do you know how is replaced the 'dist' folder in the repo https://github.com/namgk/dnr-editor ?
@davide16 I don't think Colin was providing that advice as someone who knows anything about dnr - he was just pointing to what it said in the repo's readme.
Thank you @knolleary. I read the other repo and I found the files I was searching.
So do you suggest me to use the namgk's repo or the other one to work on mqtt?
I cannot make any recommendations as I've not looked at any of them. We are only pointing you to what they say in their own repos.
