Divide 2 values in a function
How can i divide 2 values in a function ?
var Fan = context.get('Fan') || 0; // Value 0 - 100 step 5
var Pomp = context.get('Pomp') || 0; // Value 1 - 10 step 0.1
if (msg.topic == 'Fan')
    Fan = {payload: msg.payload};
    context.set('Fan', Fan);
if (msg.topic == 'Pomp')
    Pomp = {payload: msg.payload};
    context.set('Pomp', Pomp);
msg.payload = Fan / Pomp;
return msg
1/ If Pomp = 0 then you get a division by 0.
2/ You are not populating the context variables with numbers but with a { payload : }.
A possible correction:
var Pomp = context.get('Pomp') || 0.1; // Value 1 - 10 step 0.1
    Fan = msg.payload;
    Pomp = msg.payload;
return msg
Thanks, that is the solution.
