Hi everyone!
In this case i cant´t calculate the division of two variables defined in diferent functions. I want that my output will be a numeric (x/y).
How to resolve this problem?
In the first function (top left) i defined de variable x and the down i define the variable y.
But in the respective debugs appeears:
After that, i wont make a function that divide x/y and in last function i put this code:
Messages won't show up at the same time so you will need to store the messages until you have both messages. Then you can retrieve them to do your math . There are several ways to do this Google flow.set or context.set for two ways and I'm sure someone will chime in with others.
You also have to think about the case where two msgs go thru one function before a msg goes thru the second function. That could cause an incorrect result. You might be able to use a join node but not knowing what the flow prior to the two function nodes makes it hard to say.
