Hi there,
I'm using the stock NodeRed docker image and I need it to listen to port 80.
The container is running on Azure container instance. On my localhost I could simply run docker run -d -p 80:8080 nodered to map the internal port to 80.
Though this option is not provided by the azure equivalent command.
If I set the port 80 in the settings.js, I get the following error:
[error] Error: listen EACCES: permission denied 0.0.0.0:80
at Server.setupListenHandle [as _listen2] (net.js:1262:19)
at listenInCluster (net.js:1327:12)
at doListen (net.js:1460:7)
at process._tickCallback (internal/process/next_tick.js:63:19)
I think I get this error since nodered has no access to listen to port 80. Is there a good way to get this to work.
Thanks in advance for your answer.
Cheers
Timo
