Only make node-red accessible from localmachine
I run node-red in a container (in raspian) but what I do I cant get it to accept only connection on the localhost. Either its world or its no one. Have tried enable the settings.js row
uiHost: "127.0.0.1",
but that makes it non accessible from anywhere.
The docker-compose have for node-red,
ports:
  • "127.0.0.1:1880:1880"
This is so strange. It seems what I do Inside uiHost matters more then that of docker
With UIhost commented and this line in compise I have world access...
I have tried with localhost also as uihost but the result is same. No one can access it
You could whitelist ip's How to 'whitelist' IP address's that can access Node RED courtesy of @marcus-j-davies
There's a way to make node-red only listen on localhost - I can't remember what it is off the top of my head. Normally the node-red express servers listen on 0.0.0.0 which allows external and internal access and you can change that to a specific address .
Ah, here we go. In settings.js:
    /** By default, the Node-RED UI accepts connections on all IPv4 interfaces.
     * To listen on all IPv6 addresses, set uiHost to "::",
     * The following property can be used to listen on a specific interface. For
     * example, the following would only allow connections from the local machine.
     * This can be useful security when putting NR behind a reverse proxy on the same device.
    // uiHost: process.env.HOST || '127.0.0.1',
Good old docker. The uihost setting can restrict it to listening on just that network interface, but because it’s inside a container 127.0.0.1 is just the inside of that container so the browser running outside can’t get to it.
There is a way to tell docker to use only the host network (usually not advisable) or simpler don’t use docker.
I think the magic in compose is network_mode: “host”. But then that container will be fully exposed on the host network ( ie all ports etc)
I would suggest :
  • run with bridge mode (not host…)
  • have “172.17.0.1:1880:1880” in the ports configuration of your docker compose.
172.17.0.1 is (kinda) the router entry to the docker bridge network.
