Docker logging says Node-Red 'server now running at ...' but i cannot reach it with browser
Hey all,
II've been trying to get Node-Red to work via Docker on my Synology NAS for a while now. I use Docker composer for this. My lines in the docker compose file are:
nodered:
container_name: nodered
image: nodered/node-red:latest
restart: unless-stopped
ports:
- 1880:1880
volumes:
- ./volumes/nodered/data:/data
In the log of portainer i see the following:
15 Oct 14:40:26 - [info]
Welcome to Node-RED
15 Oct 14:40:26 - [info] Node-RED version: v3.0.2
15 Oct 14:40:26 - [info] Node.js version: v16.16.0
15 Oct 14:40:26 - [info] Linux 4.4.180+ x64 LE
15 Oct 14:40:31 - [info] Loading palette nodes
15 Oct 14:40:32 - [info] Settings file : /data/settings.js
15 Oct 14:40:32 - [info] Context store : 'default' [module=memory]
15 Oct 14:40:32 - [info] User directory : /data
15 Oct 14:40:32 - [warn] Projects disabled : editorTheme.projects.enabled=false
15 Oct 14:40:32 - [info] Flows file : /data/flows.json
15 Oct 14:40:32 - [info] Creating new flow file
your credentials.
15 Oct 14:40:32 - [warn] Encrypted credentials not found
15 Oct 14:40:32 - [info] Starting flows
15 Oct 14:40:32 - [info] Started flows
15 Oct 14:40:32 - [info] Server now running at http://127.0.0.1:1880/
My server gets an IP number in a subnet for all other the docker compose servers. Grafana works for as always on the same subnet and can I reach.
I cannot make it work to connect to the Node Red server with my browser but I can connect to the servers console. I'm not familiar enough to find out what is happening wrong.
Can anyone help me to get it working? Can I somehow test the status of the NodeRed Docker? In particlular the Apache webserver?
I don't use compose but I have "--network=host" in all my Docker commands that start a container, any container. I suggest you look for the equivalent in your compose files.
  1. Can you reach the host machine where node-red docker container is running from the machine where your browser client is running ?
  2. Did you use the following URL: http://<ip address host machine>:1880 to access your node-red editor ?
Hello Jan,
1 Yes, I can reach my synology host with various protocols?
2 No, I cannot reach the host over port 1880. That is the problem.
Regards
  1. What do you exactly get when trying to open following page in your browser:
    • http://<ip address host machine>:1880
  2. Can you run following command on the docker host machine to check if it is effective listening at port 1880. ?
 sudo lsof -i -P -n | grep LISTEN | grep 1880
