I have NodeRed installed in docker with Docker compose (Stack).
I was configuring a node (MODBUS Flex Server) and then appear the message "Lost connection", waiting for reconnecting.
I stop the container, kill it, remove it... and restart the machine.. but all time is the same.
I paste the bug code, for if someone can help me: CODE:
Welcome to Node-RED
3 Mar 13:23:24 - [info] Node-RED version: v2.2.0
3 Mar 13:23:24 - [info] Node.js version: v14.18.2
3 Mar 13:23:24 - [info] Linux 5.10.16.3-microsoft-standard-WSL2 x64 LE
3 Mar 13:23:24 - [info] Loading palette nodes
3 Mar 13:23:26 - [info] Dashboard version 3.1.6 started at /ui
3 Mar 13:23:26 - [info] Settings file : /data/settings.js
3 Mar 13:23:26 - [info] Context store : 'default' [module=memory]
3 Mar 13:23:26 - [info] User directory : /data
3 Mar 13:23:26 - [warn] Projects disabled : editorTheme.projects.enabled=false
3 Mar 13:23:26 - [info] Flows file : /data/flows.json
3 Mar 13:23:27 - [info] Server now running at http://127.0.0.1:1880/
**3 Mar 13:23:27 - [warn] **
your credentials.
3 Mar 13:23:27 - [info] Starting flows
3 Mar 13:23:27 - [info] [OpcUa-Client:OPC UA Prosys] Local 'own' certificate is NOT used.
3 Mar 13:23:27 - [info] Started flows
3 Mar 13:23:27 - [red] Uncaught Exception:
3 Mar 13:23:27 - [error] Error: listen EADDRNOTAVAIL: address not available 10.19.19.191:11502
** at Server.setupListenHandle [as _listen2] (net.js:1314:21)**
** at listenInCluster (net.js:1379:12)**
** at doListen (net.js:1516:7)**
** at processTicksAndRejections (internal/process/task_queues.js:83:21)**
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-red-docker@2.2.0 start: node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"
npm ERR! Exit status 1
npm ERR! Failed at the node-red-docker@2.2.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /data/.npm/_logs/2022-03-03T12_23_27_337Z-debug.log
> node-red-docker@2.2.0 start /usr/src/node-red
3 Mar 13:24:29 - [info]
THANKS SO MUCH
Jose
