Node-Red container won't restart after adding a node
Node-Red Docker container won't restart after adding a node
I'm hoping that someone can help me, perhaps someone who uses Docker has had the same problem.
I was playing about adding a Node for IFTTT, and left a port for '80' in the config. Since doing this, the Container crashed and I cannot restart the Container. Is there a way to recover from this?
I get the following log....
your credentials.
7 Dec 20:08:17 - [info] Starting flows
7 Dec 20:08:17 - [info] Added IFTTT express routes.
7 Dec 20:08:17 - [info] [ifttt-broker:MyWebHook] IFTTT broker listening on port 80
7 Dec 20:08:18 - [info] Started flows
7 Dec 20:08:18 - [red] Uncaught Exception:
7 Dec 20:08:18 - Error: listen EACCES: permission denied 0.0.0.0:80
    at Server.setupListenHandle [as _listen2] (net.js:1263:19)
    at listenInCluster (net.js:1328:12)
    at Server.listen (net.js:1415:7)
    at Function.listen (/data/node_modules/express/lib/application.js:618:24)
    at new IFTTTBrokerNode (/data/node_modules/node-red-contrib-ifttt-broker/ifttt-broker.js:42:29)
    at Object.createNode (/usr/src/node-red/node_modules/@node-red/runtime/lib/nodes/flows/util.js:483:31)
    at Flow.start (/usr/src/node-red/node_modules/@node-red/runtime/lib/nodes/flows/Flow.js:167:44)
    at start (/usr/src/node-red/node_modules/@node-red/runtime/lib/nodes/flows/index.js:345:33)
    at tryCatchReject (/usr/src/node-red/node_modules/when/lib/makePromise.js:845:30)
    at runContinuation1 (/usr/src/node-red/node_modules/when/lib/makePromise.js:804:4)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-red-docker@1.0.5 start: `node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the node-red-docker@1.0.5 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR!     /usr/src/node-red/.npm/_logs/2020-12-07T20_08_18_048Z-debug.log
> node-red-docker@1.0.5 start /usr/src/node-red
7 Dec 20:08:46 - [info]
Welcome to Node-RED
7 Dec 20:08:46 - [info] Node-RED version: v1.0.5
7 Dec 20:08:46 - [info] Node.js  version: v10.20.0
7 Dec 20:08:46 - [info] Linux 5.0.0-32-generic x64 LE
7 Dec 20:08:46 - [info] Loading palette nodes
7 Dec 20:08:47 - [info] Dashboard version 2.20.0 started at /ui
7 Dec 20:08:47 - [info] Settings file  : /data/settings.js
7 Dec 20:08:47 - [info] Context store  : 'default' [module=memory]
7 Dec 20:08:47 - [info] User directory : /data
7 Dec 20:08:47 - [warn] Projects disabled : editorTheme.projects.enabled=false
7 Dec 20:08:47 - [info] Flows file     : /data/flows.json
7 Dec 20:08:47 - [info] Server now running at http://127.0.0.1:1880/
I am not up to speed on docker but if you can add a startup parammeter you could add --safe to start up node-red in safe mode.
alternatively if you can access the file system, you could rename the xxx_flow.json file and restart - this way node-red wont load and run your flow.
Hi Steve, thanks for the reply - I didn't realise I had one!
I managed to find where the docker files where, I got it working again by deleting the ‘.flows.json’ file and renaming the ‘.flows.json.backup’ to ‘.flows.json'.
