Does anyone know a contrib-node that tracks Daylight Savings Dates?
Guys,
I have to do some time/date manipulation and want to make it more robust. DST dates do not change often but it does happen.
Does anyone know of a contrib node that can be used to pass a trigger to and it will give out a YES/No type response as to whether DST is in effect - and is kept current with DST changes as they happen ?
Craig
Actually just realised i already have one -
My only concern is there is nothing in there about keeping updated with DST changes as they occur - i assume he references some external site - but will pose the question
Craig
The DST information comes from the OS. It is not a node red issue. It is up to the user to keep his OS up to date.
I use the sun-position nodes, they seem very reliable.
I use the actual sun position though rather than relying on GMT/DST. I use it to control the house lighting.
this one gives all information for a specific location as well :wink: .. in case you need the data elements
Thanks Guys,
For context - our Power Company in Australia works off what they call NEM time - which is essentially AEDT but does not change for DST.
Therefore i need two paths in my code when parsing the times to account for whether we are in DST or not and then applying the appropriate offset.
I think the ones i am using will work OK - i essentially have an Initialisations page for all my flows - and have put it in there to check 10s after startup and then every minute during the day - it then sets a Global Variable for other routines to refer to DST: True/False.
Thanks for the pointers.
Craig
Thats a nice call on the Curl call thanks - its amazing what free stuff is out there !
Craig
Of course, anything that can be done using CURL can be done using a Node-RED request node as well. :slight_smile:
