I have attempted to craft a flow that sets a flow variable in file context storage to a string with the value being the IP:PORT of Node-RED and display in status of function.
The only non core node used is node-red-contrib-string (I will see about removing this in the future, but for testing/developing it saves me time).
If you have a minute to test it for me, it would be greatly appreciated. If you choose to, could you respond with whether or not the resulting status was valid for your install (if http://IP:PORT/ or https://IP:PORT/ brings up the editor, report valid). And if any modifications were used to get it to function correctly, or any recommendations.
My goal is to make it function correctly on as many Node-RED installation configurations as possible.
[EDIT] [Skip this flow] Here is flow 1: [REMOVED]
[EDIT] [Skip this flow] Here is flow 2: [REMOVED]
[EDIT] [Skip this flow] Here is flow 3: [REMOVED]
[EDIT] [Skip this flow] Here is flow 4: [REMOVED]
[EDIT] Here is an updated flow we'll call flow 5, a second attempt at multi-platform with OS checks:
[{"id":"fa93a8d0db17300c","type":"group","z":"8427043ceb652fb8","name":"Save Node-RED IP:PORT as a flow variable","style":{"stroke":"#e9967a","label":true},"nodes":["eb01511ae1b2e493","725055ecb7e2d269","75974486fa8d3c0c","5fcb639d39593668","0a473496d59ec53a","b6d1388d2cdf9667","918184ea29eaf45e","ef2dfbc87b4577b7","f2f028d982b0a838","8ef52d8947c12d5b","90bfe4a6c1d53f69","4ebf776c968578ba","d526b6397585be29","fd49cc71b03898e1","cd157e9770a7c6c6","a1876d79f7e61de0","9adbb9c75fc57709","0372f661a5d1f1c2","0d671a161de1e42d","6fd25156afd20d1e","82c5bd495ad105a9","eae61b440aced7e3","278bf7896f4fc418","299a72d1d01ae0e1","1282f5f1f122f731","cb1c2f9dd0026427","06bab8ed203c6c4c"],"x":34,"y":1239,"w":1572,"h":369.5},{"id":"eb01511ae1b2e493","type":"inject","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"kill","props":[{"p":"kill","v":"SIGTERM","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":270,"y":1560,"wires":[["ef2dfbc87b4577b7","f2f028d982b0a838","a1876d79f7e61de0","82c5bd495ad105a9"]]},{"id":"725055ecb7e2d269","type":"inject","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"run","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":"0.2","topic":"","payload":"","payloadType":"str","x":130,"y":1320,"wires":[["299a72d1d01ae0e1"]]},{"id":"75974486fa8d3c0c","type":"comment","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"save Node-RED IP:PORT","info":"","x":170,"y":1280,"wires":[]},{"id":"5fcb639d39593668","type":"function","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"save IP:PORT","func":"if ((typeof msg.payload === \"string\")&&(msg.payload != \"\")) {\n flow.set(\"ipPort\", msg.payload, \"file\");\n};\nnode.status({ fill: \"green\", shape: \"dot\", text: flow.get(\"ipPort\", \"file\")||msg.payload });","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1500,"y":1460,"wires":[]},{"id":"0a473496d59ec53a","type":"inject","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"check","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":1350,"y":1500,"wires":[["5fcb639d39593668"]]},{"id":"b6d1388d2cdf9667","type":"inject","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"set manually","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"127.0.0.1:1880","payloadType":"str","x":1330,"y":1420,"wires":[["5fcb639d39593668"]]},{"id":"918184ea29eaf45e","type":"function","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"format","func":"msg.payload = `${msg.ip}:${msg.port}`;\nreturn { \"payload\": msg.payload };","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1350,"y":1460,"wires":[["5fcb639d39593668"]],"info":"// nrlint function-eslint:off\n"},{"id":"ef2dfbc87b4577b7","type":"exec","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","command":"pwd","addpay":"","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"pwd unix","x":520,"y":1500,"wires":[["8ef52d8947c12d5b"],[],[]]},{"id":"f2f028d982b0a838","type":"exec","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","command":"hostname -I | cut -d ' ' -f1 | tr -d '\\n'","addpay":"","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"get ip linux","x":530,"y":1440,"wires":[["fd49cc71b03898e1"],[],[]]},{"id":"8ef52d8947c12d5b","type":"string","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"","methods":[{"name":"collapseWhitespace","params":[]},{"name":"ensureRight","params":[{"type":"str","value":"/.node-red"}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":690,"y":1500,"wires":[["90bfe4a6c1d53f69"]]},{"id":"90bfe4a6c1d53f69","type":"function","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"format","func":"msg.payload = `${msg.payload}/settings.js`;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":1500,"wires":[["4ebf776c968578ba"]],"info":"// nrlint function-eslint:off\n"},{"id":"4ebf776c968578ba","type":"file in","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"","filename":"payload","filenameType":"msg","format":"utf8","chunk":false,"sendError":false,"encoding":"none","allProps":false,"x":940,"y":1500,"wires":[["d526b6397585be29"]]},{"id":"d526b6397585be29","type":"change","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"port","rules":[{"t":"set","p":"port","pt":"msg","to":"$match(payload, /PORT \\|\\|.([0-9]+)/).groups[0]","tot":"jsonata"},{"t":"delete","p":"payload","pt":"msg"},{"t":"delete","p":"filename","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1070,"y":1500,"wires":[["cd157e9770a7c6c6"]]},{"id":"fd49cc71b03898e1","type":"change","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"set ip unix","rules":[{"t":"set","p":"ip","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"payload","pt":"msg"},{"t":"delete","p":"rc","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1060,"y":1440,"wires":[["cd157e9770a7c6c6"]]},{"id":"cd157e9770a7c6c6","type":"join","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"","mode":"custom","build":"merged","property":"","propertyType":"full","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1230,"y":1460,"wires":[["918184ea29eaf45e"]]},{"id":"a1876d79f7e61de0","type":"exec","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","command":"hostname","addpay":"","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"get ip macOS","x":540,"y":1380,"wires":[["fd49cc71b03898e1"],[],[]]},{"id":"9adbb9c75fc57709","type":"function","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"check os","func":"msg.payload = msg.operatingSystem.name[0].toLowerCase();\nif (msg.payload === \"d\") {\n node.send([{ \"payload\": \"\" }, null, null ]);\n} else if (msg.payload === \"l\") {\n node.send([ null, { \"payload\": \"\" }, null ]);\n} else if (msg.payload === \"w\") {\n node.send([ null, null, { \"payload\": \"\" }]);\n};","outputs":3,"noerr":0,"initialize":"","finalize":"","libs":[],"x":260,"y":1440,"wires":[["a1876d79f7e61de0","ef2dfbc87b4577b7"],["f2f028d982b0a838","ef2dfbc87b4577b7"],["82c5bd495ad105a9","eae61b440aced7e3"]],"outputLabels":["mac","linux","windows"]},{"id":"0372f661a5d1f1c2","type":"join","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"","mode":"custom","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"/","joinerType":"str","accumulate":false,"timeout":"","count":"3","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":930,"y":1560,"wires":[["8ef52d8947c12d5b"]]},{"id":"0d671a161de1e42d","type":"switch","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"index","v":"0","vt":"num","v2":"2","v2t":"num"}],"checkall":"true","repair":false,"outputs":1,"x":810,"y":1560,"wires":[["0372f661a5d1f1c2"]]},{"id":"6fd25156afd20d1e","type":"split","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"","splt":"\\","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":690,"y":1560,"wires":[["0d671a161de1e42d"]]},{"id":"82c5bd495ad105a9","type":"exec","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","command":"echo %cd%","addpay":"","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"pwd windows","x":530,"y":1560,"wires":[["6fd25156afd20d1e"],[],[]]},{"id":"eae61b440aced7e3","type":"function","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"get ip windows","func":"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":1320,"wires":[["1282f5f1f122f731"]]},{"id":"278bf7896f4fc418","type":"change","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"set ip windows alt","rules":[{"t":"set","p":"ip","pt":"msg","to":"0.0.0.0","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":1360,"wires":[["cd157e9770a7c6c6"]]},{"id":"299a72d1d01ae0e1","type":"function","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"os npm module","func":"// info about the current user\nmsg.user = os.userInfo();\n\n// returns the system uptime\nmsg.uptime = {\n days: (os.uptime() / 86400).toFixed(2),\n hours: (os.uptime() / 3600).toFixed(2),\n minutes: (os.uptime() / 60).toFixed(2),\n seconds: os.uptime().toFixed(2),\n};\n\n// info about the operating system\nmsg.operatingSystem = {\n name: os.type(),\n release: os.release(),\n totalMem: `${parseFloat((os.totalmem() / Math.pow(1024, 3)).toFixed(2))}GB`,\n freeMem: `${parseFloat((os.freemem() / Math.pow(1024, 3)).toFixed(2))}GB`,\n architecture: os.arch(),\n homeDir: os.homedir(),\n tempDir: os.tmpdir(),\n networkInt: os.networkInterfaces(),\n};\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"os","module":"os"}],"x":280,"y":1320,"wires":[["9adbb9c75fc57709","06bab8ed203c6c4c"]],"info":"// nrlint function-eslint:off\n"},{"id":"1282f5f1f122f731","type":"change","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"set ip windows","rules":[{"t":"set","p":"ip","pt":"msg","to":"127.0.0.1","tot":"str"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1040,"y":1400,"wires":[["cd157e9770a7c6c6"]]},{"id":"cb1c2f9dd0026427","type":"debug","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"debug 83","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":660,"y":1280,"wires":[]},{"id":"06bab8ed203c6c4c","type":"function","z":"8427043ceb652fb8","g":"fa93a8d0db17300c","name":"get info","func":"let placeholder = {\n \"homedirUser\": msg.user.homedir,\n \"homedirOS\": msg.operatingSystem.homeDir,\n};\nif (msg.operatingSystem.networkInt.eth0) {\n placeholder.eth0 = msg.operatingSystem.networkInt.eth0[0].address;\n};\nif (msg.operatingSystem.networkInt.wlan0) {\n placeholder.wlan0 = msg.operatingSystem.networkInt.wlan0[0].address;\n};\nif (msg.operatingSystem.networkInt.lo) {\n placeholder.lo = msg.operatingSystem.networkInt.lo[0].address;\n};\nmsg = placeholder;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":1280,"wires":[["cb1c2f9dd0026427"]]}]
