[Doubt]: Receiving string + real
Hi everyone,
after search here, I found how to show images on dashboard from a local path.
Now, I have to receive informations from a camera using TCP/IP and show at dashboard.
So, I used a node 'tcp in' and configure with IP/port and use Outpu as 'stream of String'...so I can listening the device(camera), but I have the follow problem:
Every message received from device contains: 'PSVB' + 'mystring'. (At this case I texted "Test")
However I need to receive data type: real. So I change at device from string to real(one variable which I need), and it sends ' PSVB '. So, anyone knows how to receive this message with caracteres more numbers?
Code:
[{"id":"92c56d3d.e7382","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"9ad3a676.fb8e18","type":"function","z":"92c56d3d.e7382","name":"action case","func":"let action = msg.payload;       //what to navigate ?\nlet numSlides = msg.numSlides;  //total pictures in the \"files\" array\nlet slideIndex = flow.get(\"slideIndex\") || 0;   //index  position picture\nlet gateSlide = flow.get(\"gateSlide\")||0;   // play or pause\n\n    switch (action) {\n        case \"play\":\n        flow.set (\"gateSlide\", true);\n            break;\n        case \"pause\":\n        flow.set (\"gateSlide\", false);\n            break;\n        case \"first\":      \n            slideIndex = 0;//go to first\n            break;        \n        case \"last\":\n            slideIndex = numSlides-1;//got to last\n            break;\n        case \"del\"://**********DELETE PICTURE **********\n            msg.fileName = flow.get(\"slides\")[slideIndex];   //Tx: name picture\n            node.send([null,{    // 2nd output : \n            fileName:msg.fileName, path:msg.path, numSlides:msg.numSlides,slideIndex:slideIndex\n            }]);    \n            return msg\n        case \"next\":\n            slideIndex++;\n            if(gateSlide === true){\n                if (slideIndex > numSlides - 1) slideIndex = 0; //repeat if played\n            } else {\n                if (slideIndex > numSlides - 1) slideIndex = numSlides-1; //stay at last if next\n                    }\n            break;\n        case \"previous\": \n            slideIndex--;\n            if (slideIndex < 0) slideIndex = 0; //stay on first\n            break;\n        default:\n            break;\n    }\nmsg.affSlideIndex = slideIndex+1;   //Tx N°  picture\nflow.set(\"slideIndex\", slideIndex); //save position for next time\nmsg.slideIndex=slideIndex;   //Tx position  picture\n\n//get name picture from slideIndex position in the \"slides\" array\nmsg.fileName = flow.get(\"slides\")[msg.slideIndex];   //Tx: picture name\n\n//alternative message if Folder is empty\nif (numSlides === 0) {\n    msg.fileName = \"Empty Folder !    \";\n    msg.affSlideIndex = 0;   //Tx N°  picture\n}\nnode.status({\"text\" : msg.fileName});        //under the node\n\n\nreturn msg;\n\n\n\n\n","outputs":2,"noerr":0,"x":610,"y":280,"wires":[["4884e9ec.ba76e8","b801b61b.5779a8"],["11b37e4.3b05b82"]]},{"id":"90503d5b.ffde9","type":"fs-ops-dir","z":"92c56d3d.e7382","name":"","path":"path","pathType":"msg","filter":"*","filterType":"str","dir":"files","dirType":"msg","x":640,"y":80,"wires":[["253f6c60.54a4b4"]]},{"id":"253f6c60.54a4b4","type":"change","z":"92c56d3d.e7382","name":"set array in flow.slides","rules":[{"t":"set","p":"slides","pt":"flow","to":"files","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":80,"wires":[["54bb6dc4.541184"]]},{"id":"54bb6dc4.541184","type":"function","z":"92c56d3d.e7382","name":"Set numSlides","func":"let totalPic = flow.get(\"slides\").length;   //get sise of array\nnode.status({text:totalPic});   // display under node\nmsg.numSlides = totalPic;//Tx: numSlides = total pictures in the files array\nreturn msg;\n\n/*  Tx en sortie : \n\n*/","outputs":1,"noerr":0,"x":1020,"y":80,"wires":[["9ad3a676.fb8e18"]]},{"id":"43321266.29243c","type":"inject","z":"92c56d3d.e7382","name":"Go","topic":"","payload":"Initialize pictures","payloadType":"str","repeat":"","crontab":"","once":true,"onceDelay":"1","x":330,"y":40,"wires":[["f54067c5.9ce6f8"]]},{"id":"f54067c5.9ce6f8","type":"function","z":"92c56d3d.e7382","name":"set path","func":"//let path=flow.get('picturePath');\npath = \"C:/Users/franc/.node-red/node-red-static/Robotika\";\n//flow.set ('picturePath',path);    //save picturePath : le chemin du dossier des pictures\nmsg.path = path;\nreturn msg;\n","outputs":1,"noerr":0,"x":500,"y":80,"wires":[["90503d5b.ffde9"]]},{"id":"438773ec.a7331c","type":"link in","z":"92c56d3d.e7382","name":"getPath","links":["271aca69.06a7c6","d4dc51cb.4e0ef","6816661c.dc4008","f8f338.7920fcc8","4616e465.e9e8cc","3a414b07.7ceb94","fd02b897.8eecd8"],"x":575,"y":140,"wires":[["f54067c5.9ce6f8"]]},{"id":"4884e9ec.ba76e8","type":"ui_template","z":"92c56d3d.e7382","group":"332c9960.a38046","name":"img","order":1,"width":"0","height":"0","format":"<!DOCTYPE html>\n<html>\n<head>\n<style>\ndiv.parent {\n  position: relative;\n  height: 480px ;\n}\ndiv.absolute {\n  position: absolute;\n  width: 100%;\n  bottom: 0px;\n} \n\n</style>\n</head>\n<body>\n    <div class=\"parent\">\n        <div class=\"absolute\" >\n        <img src=\"/Robotika/{{msg.fileName}}\" alt=\"Camera Picture\" style=\"width:100%\"><br>\n        {{msg.fileName}} {{msg.affSlideIndex}}/{{msg.numSlides}} \n        </div>\n    </div>\n</body>\n</html>\n<!--EXPLICATION  :  https://www.w3schools.com/cssref/tryit.asp?filename=trycss_position_bottom -->\n\n<!-- ////// SIMPLE VERSION //////////\n<style>        \nimg {\n    width: 100%;\n    height: auto;\n    border:1px solid green;\n}\n</style>\n<body>\n<div >\n<img src= \"/camAlerte/{{msg.fileName}}\" alt=\"Camera Picture\"   ><br>\n</div>\n</body>\n\n\n\n\n-->\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":830,"y":240,"wires":[[]]},{"id":"b801b61b.5779a8","type":"ui_text","z":"92c56d3d.e7382","d":true,"group":"40e977fa.504fb8","order":12,"width":5,"height":1,"name":"picName/number","label":"{{msg.fileName}}","format":"{{msg.affSlideIndex}}/{{msg.numSlides}}","layout":"row-spread","x":870,"y":200,"wires":[]},{"id":"11b37e4.3b05b82","type":"fs-ops-delete","z":"92c56d3d.e7382","name":"del","path":"path","pathType":"msg","filename":"fileName","filenameType":"msg","x":810,"y":280,"wires":[["e8dc5fa7.23a16"]]},{"id":"3a414b07.7ceb94","type":"link out","z":"92c56d3d.e7382","name":"getPath","links":["438773ec.a7331c"],"x":1095,"y":240,"wires":[]},{"id":"e8dc5fa7.23a16","type":"function","z":"92c56d3d.e7382","name":"Stay at last","func":"let slideIndex = msg.slideIndex;\nlet numSlides = msg.numSlides;\n    if (slideIndex<numSlides-1) {\n            msg.payload=\"next\"\n        } \n        else { msg.payload=\"play\" }        \nreturn msg;\n","outputs":1,"noerr":0,"x":950,"y":280,"wires":[["3a414b07.7ceb94"]]},{"id":"4dfb898b.87e218","type":"inject","z":"92c56d3d.e7382","name":"","topic":"","payload":"next","payloadType":"str","repeat":"1","crontab":"","once":true,"onceDelay":"1","x":230,"y":80,"wires":[["f54067c5.9ce6f8"]]},{"id":"6e5c960c.57c128","type":"comment","z":"92c56d3d.e7382","name":"Read me","info":"## **Prerequisites**\nThis Flow work in the Raspberry with Raspbian and Node-red installed\n - Requires the installation of contrib node: **fs-ops-dir**.\n - Create folders in Node-RED and populate it with pictures. (The difference with Andrei Flow is that I don't display the images in the background). => **1/**\n - Requires **Context Storage** and **httpStatic** activated change the settings.js file in the raspberry => **2/**.\n\n\n## **How to do prerequisites ?**\n**1/**  in the `/home/pi/Documents` Folder : create a new Foder named: `node-red-static`\nin this `/home/pi/Documents/node-red-static` Folder , create a new Folder named: `camAlerte`\n\n**2/** this flow use context storage: in the `/home/pi/.node-red` Folder , open the `settings.js`and  verify (around line 222) must be like this : \n```\n    // Context Storage\n    // The following property can be used to enable context storage. The configuration\n    // provided here will enable file-based context that flushes to disk every 30 seconds.\n    // Refer to the documentation for further options: https://nodered.org/docs/api/context/\n    //\n    contextStorage: {\n        default: {\n            module:\"localfilesystem\",\n\t\t\tconfig: {\n\t\t\t\tdir:\"~/.node-red\",\n\t\t\t\tbase:\"context\",\n\t\t\t\tcache:true,\n\t\t\t\tflushInterval:30\n\t\t\t}\n        },\n    },\n```\n\n **And** add (modify) a line (around line108) ,like this : \n```\n    // When httpAdminRoot is used to move the UI to a different root path, the\n    // following property can be used to identify a directory of static content\n    // that should be served at http://localhost:1880/.\n\t//httpStatic: '/home/nol/node-red-static/',\n    httpStatic: '/home/pi/Documents/node-red-static',\n```\n(of course , you can change the location and the name of the directory)\n## **How it works**\nAfter indicating the folder of images, the **fs-ops-dir** node create an array of pictures name contained in the folder. It only remains to display the desired image by indicating its position in the table. It's a template node that will format a message to display the picture.\n\nBelow the code inside this template node.\n\n`<img src=\"/camAlerte/{{msg.fileName}}\" alt=\"Camera Picture\" style=\"width:100%\"><br>`\n\n\n## **Built and tested With**\n* [Node-RED]  - version 1.0.3\n* [Dashboard] - version 2.19.4 \n","x":480,"y":40,"wires":[]},{"id":"2714c560.8085ea","type":"ui_template","z":"92c56d3d.e7382","group":"a3f0a56e.200958","name":"Logo / Clock","order":0,"width":0,"height":0,"format":"<script id=\"clockScript1\" type=\"text/javascript\">\n    var clockInterval;\n    $(function () {\n        if (clockInterval) return;\n\n        //add logo\n        var div1 = $('<div/>');\n        var logo = new Image();\n\n        logo.src = '/Robotika/logo.png'\n        logo.height = 65;\n        div1[0].style.margin = '5px auto';\n\n        div1.append(logo);\n\n        //add clock\n        var div2 = $('<div/>');\n        var p = $('<p/>');\n\n        div2.append(p);\n        div2[0].style.margin = '5px';\n\n        function displayTime() {\n            p.text(new Date().toLocaleString());\n        }\n        \n        clockInterval = setInterval(displayTime, 1000);\n\n        //add to toolbar when it's available\n        var addToToolbarTimer;\n        \n        function addToToolbar() {\n            var toolbar = $('.md-toolbar-tools');\n            \n            if(!toolbar.length) return;\n            \n            toolbar.append(div1);\n            toolbar.append(div2);\n            clearInterval(addToToolbarTimer);\n        }\n        addToToolbarTimer = setInterval(addToToolbar, 100);\n    });\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"global","x":950,"y":20,"wires":[[]]},{"id":"654b6252.8a7dfc","type":"debug","z":"92c56d3d.e7382","name":"Show information","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":790,"y":420,"wires":[]},{"id":"a3aa9d81.c3188","type":"tcp in","z":"92c56d3d.e7382","name":"Node-RED Client","server":"client","host":"169.254.154.100","port":"36701","datamode":"stream","datatype":"utf8","newline":"","topic":"Msg from BVS","base64":false,"x":260,"y":420,"wires":[["654b6252.8a7dfc"]]},{"id":"332c9960.a38046","type":"ui_group","z":"","name":"Inspeção Visual","tab":"6e51523d.4c5cfc","order":1,"disp":true,"width":"12","collapse":false},{"id":"40e977fa.504fb8","type":"ui_group","z":"","name":"Slideshow","tab":"","order":1,"disp":true,"width":"10","collapse":false},{"id":"a3f0a56e.200958","type":"ui_group","z":"","name":"Default","tab":"","order":1,"disp":false,"width":"24","collapse":false},{"id":"6e51523d.4c5cfc","type":"ui_tab","z":"","name":"rotótipo","icon":"","order":1,"disabled":false,"hidden":false}]
Hi Francklin, welcome to the forum.
Please be aware that any code or flows posted in the forum needs to be correctly formatted, otherwise other users will not be able to load it.
Please see How to share code or flow json and using the pencil icon in your post above, edit the post so that the flow is displayed correctly.
Hi Paul!
Thank you for the tip.
Now it's ok
