The flow it's pretty straight forward. a GET Endpoint calling a MySQL Stored Procedure.
Retrieving the data and using the CSV node to convert the Javascript object into csv string.
Now, there are a lot of varchar fields in the DB with accent mark (í,ó,ñ) so im trying to download the csv file with utf-8 encoding:
(image from last function node, before the http end)
Haven't been able to succeed with that.
I also tried the File node (after the csv) to save it with the encode option utf-8, didn't work either.
So, im not sure how to approach this
