hello,everyone,i can use exec node to do something like remove a file in linux (example:rm xxx.txt), but it cant download a node module(like npm install node-red-node-mysql)
have a good way to do that?
What error does that return?
Check the other outputs of the exec node.
Why are you using -g? Normally that would need sudo permissions to run. Also you have selected Append msg.payload, what have you got in the payload that you are appending to the command?
As @Colin says, the Exec node has three output ports. Connect them all to a Debug node to see the output - any error messages from the command will be emitted from the second port.
You can see the command it is running has 155549101984 at the end.
That is because, just as @Colin said in his reply, you have the append msg.payload option enabled in the Exec node - so it is adding the timestamp from the Inject node to the end of the command.
Disable that option in the Exec node and it should work.
thank you very much,i will try it
(my emotion now)
thank you very much
