maybe because your 'simulated' data doesnt match the 'real' context.
send us a screenshot of the context data from your real flow .. expanded so we can see the whole structure pls
i think i found the issue .. you need an extra space infront of VALUES in sql query .. try this
because your sql resolves to
"INSERT INTO Andadores (ID_and,ID_pac,Inicio)VALUES (54,26,2020-7-1)"
Like this :
msg.topic = "INSERT INTO Andadores (ID_and,ID_pac,Inicio)"+ " VALUES ("+id_and+","+idpacs+","+inicio+")";
the space outside the " " doesnt count
an even cleaner syntax is this .. using backticks ` .. not to be confused with single quotes '
msg.topic = `INSERT INTO Andadores (ID_and,ID_pac,Inicio) VALUES (${id_and},${idpacs},${inicio})`;
Thanks!
But no, it does not work. The issue its:
idpacs = idpacs.payload[0];
If I don“t use that, then it returns the message to the output but well, the value its the object Object thing that is ruining it.
Thing is, I have used that line outside the flow Im trying to make work and it access to the value ID_pac, which is the goal. I don“t know what is happening.
i thought it should have been
idpacs = idpacs.payload[0].ID_pac // here
what did you try ?
because in the simulation it works
I have found the solution.
var idpacs = flow.get("flow");
idpacs = idpacs[0].ID_pac;
Once you store the context variable in the variable, you no longer need the .payload because now its called idpacs... I have been trying it in an independent flow to check what was happening until I realised it.
Thansk for the help. This was driving me crazy.
cool .. im glad you found it
im not sure if you know this but if you want to check your context ..
you go in the upper top right corner triangle and choose Context Data and refresh for the 'Flow'
No I didn“t know it..it“s my first time doing this. Thanks!!
