You can send all the values from each array element if you wish.
You can send as an object (works fine for simple objects, not to large), or you can send as string and convert to an object after selection.
example of both.
[{"id":"e171772c0bc3477d","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"d_waarde\":1,\"d_max\":2,\"d_min\":3,\"name\":\"bob\"},{\"d_waarde\":2,\"d_max\":2,\"d_min\":3,\"name\":\"bill\"},{\"d_waarde\":3,\"d_max\":2,\"d_min\":3,\"name\":\"ben\"}]","payloadType":"json","x":110,"y":1440,"wires":[["80fcc958bb9ba4aa"]]},{"id":"80fcc958bb9ba4aa","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"set","p":"options","pt":"msg","to":"$$.payload.{$.name: $}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":1440,"wires":[["ab2e9a2804ad7892","78c8edc889f86bd0"]]},{"id":"ab2e9a2804ad7892","type":"ui_dropdown","z":"452103ea51141731","name":"","label":"","tooltip":"","place":"Select option","group":"2d4fe667.28f8ba","order":17,"width":0,"height":0,"passthru":false,"multiple":false,"options":[],"payload":"","topic":"topic","topicType":"msg","className":"","x":420,"y":1480,"wires":[["78c8edc889f86bd0"]]},{"id":"78c8edc889f86bd0","type":"debug","z":"452103ea51141731","name":"debug 100","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":550,"y":1440,"wires":[]},{"id":"1b82aa02021d95e8","type":"inject","z":"452103ea51141731","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"d_waarde\":1,\"d_max\":2,\"d_min\":3,\"name\":\"bob\"},{\"d_waarde\":2,\"d_max\":2,\"d_min\":3,\"name\":\"bill\"},{\"d_waarde\":3,\"d_max\":2,\"d_min\":3,\"name\":\"ben\"}]","payloadType":"json","x":90,"y":1560,"wires":[["8211356b5dd309f5"]]},{"id":"8211356b5dd309f5","type":"change","z":"452103ea51141731","name":"","rules":[{"t":"set","p":"options","pt":"msg","to":"$$.payload.{$.name: $string($)}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":240,"y":1560,"wires":[["9b692f6a668f10e2","c59484177b4c27b8"]]},{"id":"9b692f6a668f10e2","type":"ui_dropdown","z":"452103ea51141731","name":"","label":"","tooltip":"","place":"Select option","group":"2d4fe667.28f8ba","order":17,"width":0,"height":0,"passthru":false,"multiple":false,"options":[],"payload":"","topic":"topic","topicType":"msg","className":"","x":400,"y":1600,"wires":[["67131e8b3bfb70a5"]]},{"id":"67131e8b3bfb70a5","type":"json","z":"452103ea51141731","name":"","property":"payload","action":"","pretty":false,"x":550,"y":1600,"wires":[["c59484177b4c27b8"]]},{"id":"c59484177b4c27b8","type":"debug","z":"452103ea51141731","name":"debug 101","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":630,"y":1560,"wires":[]},{"id":"2d4fe667.28f8ba","type":"ui_group","name":"demo","tab":"1caa8458.b17814","order":2,"disp":true,"width":"12","collapse":false},{"id":"1caa8458.b17814","type":"ui_tab","name":"Demo","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
$$.payload.{ // $$ (msg context).payload.(map each element to $ context) { (create object)
$.name: $string($) // $ ($ context).name (object property name): $string($) ( set property value to $ context but convert to string)
} // Close object, map next element
