Hi Nick,
Thanks for your reply, it is very appreciated.
All the droplist won't populate but all the other fields (Textbox or label) are populated by the Mysql Query result. I have several tabs with mix of Droplist othe field types and they all have the same behaviors.
The switch node validate the Tab name and it is working well.
- Queries are done
- the droplist won't populate.
On the same tab, if instead I use Inject,
- Queries are done
- the droplist are populated.
Thanks a lot and thanks so mutch for this wonderful product
Node-Red : 2.1.3
nodeJ: node-v16.13.0
Rasp Pi : has been updated as well
On the console logs, I get this error message when I open a TAB who should to a request on My SQL
1 Nov 16:50:14 - [warn] [http response:http out dash] No response object
Here is an exemple the code
[{"id":"a7829e8b94ca047e","type":"subflow","name":"Query - Dynamic","info":"","category":"","in":[{"x":65,"y":75,"wires":[{"id":"350789b45ba53fb3"}]}],"out":[{"x":560,"y":75,"wires":[{"id":"1331a762b80ebe09","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"1331a762b80ebe09","type":"mysql","z":"a7829e8b94ca047e","mydb":"a9587441.1a7a98","name":"DB - Bmind","x":430,"y":75,"wires":[[]]},{"id":"350789b45ba53fb3","type":"function","z":"a7829e8b94ca047e","name":"prepareQuerysc","func":"var query=msg.sql;\nmsg.topic = query;\nreturn msg;\n\n\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":230,"y":75,"wires":[["1331a762b80ebe09"]]},{"id":"a9587441.1a7a98","type":"MySQLdatabase","name":"DB - Bmind","host":"192.168.0.254","port":"3306","db":"Raysub1","tz":"","charset":""},{"id":"d2b3f29cabb012cb","type":"ui_ui_control","z":"20638da65a4e7b54","name":"","events":"all","x":105,"y":135,"wires":[["05c833f73d466912"]]},{"id":"05c833f73d466912","type":"switch","z":"20638da65a4e7b54","name":"","property":"name","propertyType":"msg","rules":[{"t":"eq","v":"Inventory-Add","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":95,"y":180,"wires":[["07f99f3172d5edef","bf07927bcae33e6f"],[]]},{"id":"bf07927bcae33e6f","type":"link out","z":"20638da65a4e7b54","name":"","links":["6c231bb996139c64","dca4c8df7dc25830"],"x":255,"y":135,"wires":[]},{"id":"dca4c8df7dc25830","type":"link in","z":"20638da65a4e7b54","name":"selection_in","links":["bf07927bcae33e6f"],"x":360,"y":240,"wires":[["bb3e23d67b251664"]]},{"id":"bb3e23d67b251664","type":"change","z":"20638da65a4e7b54","name":"Set Query","rules":[{"t":"set","p":"sql","pt":"msg","to":"SELECT * FROM Parts_Category;","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":495,"y":240,"wires":[["560c968aa12f489e"]]},{"id":"560c968aa12f489e","type":"subflow:a7829e8b94ca047e","z":"20638da65a4e7b54","name":"","env":[],"x":690,"y":240,"wires":[["5803d21104f84ce3"]]},{"id":"5803d21104f84ce3","type":"function","z":"20638da65a4e7b54","name":"format array of objects for dropdown ","func":"//Reformat array to work with dashboard\nvar reformattedArray = msg.payload.map(obj =>{\n //declare the reformatted object\n var rObj = {};\n //format it for drop down\n //\"label\":\"value\" is the format so lets move the value to the label and add some txt as well\n //you can also replce the txt with a var if you want\n rObj[obj.name] = obj.idCategory;\n return rObj;\n});\nmsg.payload = reformattedArray;\nreturn msg;\n\n//Reformat array to work with dashboard\n/*var reformattedArray = msg.payload.map(obj =>{\nvar rObj = {};\nrObj[obj.boatname+\" \"+obj.temp.toFixed(1)+\"°C\"+' | '+(((obj.temp*9)/5)+32).toFixed(1)+\"°F\"] = obj.idboat;\nreturn rObj;\n});*/\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":990,"y":240,"wires":[["2928df797d4babb6"]]},{"id":"2928df797d4babb6","type":"change","z":"20638da65a4e7b54","name":"","rules":[{"t":"set","p":"options","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"Part Category","tot":"str"},{"t":"set","p":"records","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1295,"y":240,"wires":[["33d76b4e1856fd0e"]]},{"id":"33d76b4e1856fd0e","type":"ui_dropdown","z":"20638da65a4e7b54","name":"DL_Part_Cat","label":"{{msg.topic}}","tooltip":"","place":"","group":"9a0a523fe3e4c330","order":1,"width":6,"height":1,"passthru":true,"multiple":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"SelectDone","topicType":"msg","className":"","x":1525,"y":240,"wires":[["f4c08d8dbe946b66","47c40e86839fc384"]],"outputLabels":["loulou"]},{"id":"f4c08d8dbe946b66","type":"change","z":"20638da65a4e7b54","name":"Cat_Part_ID","rules":[{"t":"set","p":"Cat_Part_ID","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1795,"y":240,"wires":[[]]},{"id":"9a0a523fe3e4c330","type":"ui_group","name":"DropList","tab":"8a11ed5db152ab89","order":4,"disp":false,"width":"18","collapse":false,"className":""},{"id":"8a11ed5db152ab89","type":"ui_tab","name":"Inventory-Add","icon":"dashboard","order":12,"disabled":false,"hidden":false}]
