Dear people,
I have a input_number node. With a slider i set the value to 12. Ik want to set this value in the trigger node so that the trigger node fires off after 12 minutes.
Can anyone tell me how can I get this done?
Thanks,
Peter
Dear people,
Thanks,
Peter
Hi @kroonp
Connect your input_number Node to the trigger Node, with the following settings.
adjust as you see fit
EDIT
I should have read more. ![]()
tick the box override delay with msg.delay
and use msg.delay to hold the 12 (but in ms)
so 720000
so along with your value, also include a property of msg.delay
Thank you, it didn't work for me because I used seconds instead of milliseconds
multiply seconds by 1,000!
