I want to dynamically change the configuration of the smb node.
All the parameters are listed below:
How can I do this?
If the node author hasnt implement dynamic methods then you cannot.
Best you can do without raising a feature request or forking & fixing it yourself is you use Environment Variables instead of hard coded values.
Hmm this is a little bit above my knowledge I think...
This will be hard.
If you look at the issues on the node's github page you will see there are multiple unnadressed issues. It appears the node is no longer supported so I think you need to find an alternative solution.
