Dynamically hide or show custom UI node content
Hi folks,
In my new custom UI node I would like to be able to hide or show my component dynamically. We had a rather similar discussion some time ago, but then we wanted "always" to hide or show the content.
This is how it works:
  1. The UI node shows its content, i.e. a DIV element with a video element inside.
  2. The user clicks a button to hide the video.
  3. My UI node sends a message to my client-side to hide the content.
  4. In the client side, I hide the video element by removing it from its parent (i.e. the div element):
    // Watch input messages arriving from the Node-RED flow
    $scope.$watch('msg', function(newVal, oldVal) {
       switch(newVal.payload) {
          case "show_video":
             // Add the video element to the DOM tree
             $scope.divElement.appendChild($scope.videoElement);
             break;
          case "hide_video":
             // Remove the video element from the DOM tree
             $scope.divElement.removeChild($scope.videoElement);
             break;
As you can see in the screenshot, the video element is hidden but the empty space remains.
When I look in the Chrome inspector, I see indeed (while my div has height 100%) that the md-card element has fixed dimensions in pixels:
Is there any way around this?
[EDIT] or is this against the whole md-card dimension mechanism of the dashboard. Should I instead workaround it by show a dummy image (e.g. like 'press to start playing ...')?
Thanks !!!
Bart
Yes fairly much against the design. Groups of nodes are a fixed size. You can hide the entire group or not. Having widgets resize can lead to the layout changing completely which would be very annoying.
Can understand that! Will workaround it then by showing dummy content. The whole idea in this case is that I don't want to empty the smartphone battery, by always displaying video.
AFAIK smartphones are pretty efficient at showing video.. I can watch movies no problem. Its the data transfer that kills the battery
