Hey,
I am using a get method on a http request node to get a temperature value from my heating.
It ends up in a function:
msg.payload = [{temp: msg.payload.eta.value[0].$.strValue},{room: "aussen"}]
return msg
unfortunately, the value in my array is like this:
temp: "7.5" (Degrees)
and not as it should be
temp: 7.5
So how can I remove these quotation marks?
Greetings
Surround the assignment value with parseInt()
msg.payload = [{temp: parseInt(msg.payload.eta.value[0].$.strValue)},{room: "aussen"}]
Ps,
Hi, in order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
It has been pointed out to me I should have said parseFloat not parseInt
I mislead you. I'm tired
lol
Oh, what Happens If i do parsint?
parseInt will turn "7.5" into 7
parseFloat will turn "7.5" into 7.5
Ah, of course! I was just wondering...
Hey Steve,
I still have the problem, that e.g. 10.8 transforms into 10.
I do it like this now:
msg.payload = [{temp: parseFloat(msg.payload.eta.value[0].$.strValue)},{room: "aussen"}]
return msg
debugging result looks like this:
10,8 is not 10.8
you will need to replace "," with "."
e.g...
parseFloat(msg.payload.eta.value[0].$.strValue.replace(',','.').replace(' ',''))
