"id": "b6a400ad4103aa9a",
"type": "tab",
"label": "Flow 6",
"disabled": false,
"info": "",
"env": []
"id": "36a45ee7decc3ea4",
"type": "template",
"z": "b6a400ad4103aa9a",
"field": "payload",
"fieldType": "msg",
"format": "handlebars",
"syntax": "mustache",
"template": "<!DOCTYPE html>\n<html>\n <head>\n <link href=\"https://cdn.jsdelivr.net/npm/bootswatch@4.5.2/dist/slate/bootstrap.min.css\" rel=\"stylesheet\"></link>\n </head>\n<body>\n <div class=\"container\">\n<table class=\"table table-hover\">\n <thead>\n <tr>\n <th scope=\"col\">Name</th>\n <th scope=\"col\">Url</th>\n <th scope=\"col\"></th>\n </tr>\n </thead>\n <tbody>\n {{#payload}}\n <tr class=\"table-active\">\n <td>{{name}}</td>\n <td>{{url}}</td>\n <td><a href=\"/monitor/feed/delete/{{rowid}}\" class=\"btn btn-danger\">Delete</a></td>\n <td><a href=\"/monitor/feed/update/{{rowid}}\" class=\"btn btn-info\">Update</a></td>\n </tr>\n {{/payload}}\n </tbody>\n</table>\n<form method=\"post\" action=\"/monitor/feed\">\n<label for=\"name\">Name</label>\n<input class=\"form-control\" id=\"name\" name=\"name\">\n<label for=\"url\">Url</label>\n<input class=\"form-control\" id=\"url\" name=\"url\">\n<button type=\"submit\" class=\"btn btn-primary\">Submit</button>\n</form>\n</div>\n</body>\n</html>",
"output": "str",
"x": 400,
"y": 100,
"e12ad503e2802482",
"d388bdb7ebed77bd"
"id": "3e31539271bac692",
"type": "http in",
"url": "/monitor/feed",
"method": "get",
"upload": false,
"swaggerDoc": "",
"x": 170,
"y": 80,
"4fca18d8bfe64d48"
"id": "e12ad503e2802482",
"type": "http response",
"statusCode": "",
"headers": {},
"x": 630,
"y": 100,
"id": "4fca18d8bfe64d48",
"type": "sqlite",
"mydb": "daa251e133e46125",
"sqlquery": "fixed",
"sql": "SELECT rowid,* From feed;",
"x": 250,
"y": 140,
"36a45ee7decc3ea4"
"id": "c11ae811ee0b3a2e",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "CREATE TABLE feed(name,url) ",
"payload": "",
"payloadType": "date",
"x": 160,
"y": 460,
"222065ce84a4d675"
"id": "222065ce84a4d675",
"type": "sqlite",
"sqlquery": "msg.topic",
"sql": "",
"x": 330,
"y": 480,
"75107e6f171430e5"
"id": "75107e6f171430e5",
"type": "debug",
"name": "debug 2",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 500,
"y": 460,
"id": "d388bdb7ebed77bd",
"type": "debug",
"name": "debug 3",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"x": 700,
"y": 260,
"id": "fd70fc0559a38834",
"type": "http in",
"method": "post",
"upload": false,
"swaggerDoc": "",
"x": 90,
"y": 240,
"58aa4ecb409af1d5"
"id": "58aa4ecb409af1d5",
"type": "template",
"name": "INSERT",
"field": "topic",
"fieldType": "msg",
"format": "sql",
"template": "INSERT INTO feed values ('{{payload.name}}','{{payload.url}}');",
"output": "str",
"x": 300,
"y": 240,
"68add7222294ed17"
"id": "68add7222294ed17",
"type": "sqlite",
"sql": "SELECT * From feed;",
"x": 490,
"y": 240,
"4fca18d8bfe64d48"
"id": "c341b4f6b8da48f4",
"type": "http in",
"url": "/monitor/feed/delete/:rowid",
"method": "get",
"upload": false,
"swaggerDoc": "",
"x": 150,
"y": 300,
"c5e828a6a4bdcac6"
"id": "c5e828a6a4bdcac6",
"type": "template",
"name": "DELETE",
"field": "topic",
"fieldType": "msg",
"format": "sql",
"template": "DELETE from feed where rowid={{req.params.rowid}};",
"output": "str",
"x": 380,
"y": 300,
"68add7222294ed17"
"id": "78575cd0a687da9d",
"type": "http in",
"url": "/monitor/feed/update/:rowid",
"method": "put",
"upload": false,
"swaggerDoc": "",
"x": 150,
"y": 380,
"2ab2453ff2c3b7c5"
"id": "2ab2453ff2c3b7c5",
"type": "template",
"name": "UPDATE",
"field": "topic",
"fieldType": "msg",
"format": "sql",
"template": "UPDATE feed SET name={{payload.name}},url={{payload.url}} where rowid={{req.params.rowid}};",
"output": "str",
"x": 400,
"y": 380,
"68add7222294ed17"
"id": "daa251e133e46125",
"type": "sqlitedb",
"db": "demo",
"mode": "RWC"
Dear NodeRed Community,
We would require some support in Updating Functionality(CRUD) for values stored in using Sqlite Database.
