I am using a template node to execute a query in sqlite using the msg.topic.
My query is:
select * from rfidtaglist where id={{payload.id}};
On the debug i can see that in the query paylaod.id is replaced by an integer while it shoud be string.
If i execute the query:
select * from rfidtaglist where id='2';
I do get a value back. How to force string inside using mustache?
hmm .. you could pass it from a Change node and make it to a string with a Jsonata Expression
But do you really need to ?
Cant you simply surround the numeric value with single quotes in the Template node directly ?
select * from rfidtaglist where id='{{payload.id}}';
sqlite should consider it as string
Hummm. second option works fine.I'tried it before without success, maybe i was having a typo error. Many thanks.
